Broadcast sheet? #712812
05/31/10 09:10 PM
05/31/10 09:10 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
I have a 70 SE Challenger, it has been in my family sense 1987 between my brother and I.The car has a broadcast sheet has has been in the rear seat sense we owned the car and that is where we left it. My brother and I got it out this weekend to take a look at it.It is a y13 dealet demo car and has alot of options. None of the options was marked on the broadcast sheet.The only thing marked was the top portion of sheet. Anybody ever seen want like this
Re: Broadcast sheet? [Re: b5a12bee] #712813
05/31/10 09:17 PM
05/31/10 09:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Does it say Chrysler Corporation Broadcast at the top or 'Vehicle traveler' ?
If it says broadcast then it sounds like there was a printer malfunction, it happened.
Can you scan it & email it to me?
Also, look inside both front seat backs, you may find one or two broadcast sheets.
Re: Broadcast sheet? [Re: b5a12bee] #712814
05/31/10 09:18 PM
05/31/10 09:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It's possible that your sheet is just badly faded. If not it sounds like a misprinting. Post a good picture of it if you can, or if you'd like to keep it private just e-mail me a copy.
Scott bugframes@msn.com
Re: Broadcast sheet? [Re: ScottSmith_Harms] #712815
05/31/10 09:41 PM
05/31/10 09:41 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
It says Chrysler corp car production broadcast.
It may have been a printer malfunction. The steering column and torsion bar section looks like it was double printed.
Re: Broadcast sheet? [Re: b5a12bee] #712816
05/31/10 09:55 PM
05/31/10 09:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That printer must have jammed then. The sub-assembly area where the rear seats were done only needed to know the interior code & what type of car, so they could have gotten by with it just fine.
Time to check the other areas for more;
Taped to the back side / top of the glove box insert.
Under the front bucket seats in the springs
Inside the bucket seat backs
Under the rear seat bottom
Under the package tray (speaker shelf)
Under the carpet
Best of luck.
Re: Broadcast sheet? [Re: Alaskan_TA] #712817
06/01/10 06:43 PM
06/01/10 06:43 PM
Alabama
BigMoneyLewis Offline
Alabama
If it's a Hamtramck car, pull the plastic backs of the bucket seats . That's where the "Best" buildsheets are found.
Greg
gregward@mchsi.com phone 256-852-0955
