Re: BOOM! [Re: daytona5812] #712750
06/01/10 07:54 AM
06/01/10 07:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I've been side lined myself. First race, second pass, I lost control of the car at 800 ft & hit the wall at about 140 mph. Can't find parts to put back together. So I'll be spectating for awhile.
Let me know if you want a loaner.
Wow Vern, I did not know this and I'm sorry for your bad luck. Hopefully your motor isn't hurt too bad Al and just could use a 'freshen-up'. I'd guess the valvesprings are shot minimum and maybe that caused some of the other problems? Either way I hope it's not too costly.
Re: BOOM! [Re: Al_Alguire] #712751
06/01/10 10:03 AM
06/01/10 10:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
"BOOM!" sucks.
Been there, doing that right now...
Re: BOOM! [Re: BradH] #712752
06/01/10 10:15 AM
06/01/10 10:15 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Wish it were the springs. They are fine, would be an easy fix though.
The car had a fuel pump issue in Vegas and we were playing with a new carb(mistake)as well. To say it got lean would be an understatement. The car was not pulling there at all as it usually does. Only went 8.48 in Vegas and only managed 160.
I also had an oil pump issue a week later, lost oil pressure somewhere on track saw it just before the stripe had only 10lbs. Still not sure though. We dropped the pan and it all looked ok, put on a new pump and pressure was fine.
As for the current issue I have had problem with low vacuum in the crankcase for the last two outings. Not really low, just not where it had always been. On the last pass I made yesterday I was watchign the gauges pretty good, all were fine but the vacuum, it was low and fluttering pretty good. I am going to assume I have a ring seal issue, and the leakdown kind of confirmed that thought.
No big deal I just need to get it freshened. The question is do I make any changes and try and squeeze any more out of it or just freshen it and go back at it. I am leaning toward the latter.
Re: BOOM! [Re: Al_Alguire] #712753
06/01/10 10:32 AM
06/01/10 10:32 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I think you pretty much summed it up yesterday when you said... "Pay a little bit now (to freshin it up) or pay alotta bit later (when it goes boom)"
Re: BOOM! [Re: Jeepmon] #712754
06/01/10 10:45 AM
06/01/10 10:45 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Al, I am sorry to hear about your misfortune. I sent you a pm with a suggestion. I was thinking that 500 was pretty strong at MATS.
Re: BOOM! [Re: camastomcat] #712755
06/01/10 04:09 PM
06/01/10 04:09 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Al, I think you have the right idea in selling the car if you want to go as as fast as i think you do. Are you thinking of racing heads up? Then you would need a a CM chassis and a BIG mill. There are some good deals on hemi99 motors right here on moparts, or you could see about that billet block and go with some 99 heads..that would get you up around 700 ci and 1500+ HP.
Re: BOOM! [Re: Al_Alguire] #712756
06/01/10 07:26 PM
06/01/10 07:26 PM
Tucson, Arizona
johnnyrotten Offline
Tucson, Arizona
Freshin' it up and go have more fun! What kind of heads you looking for? Drop me a pm if you want.
Re: BOOM! [Re: johnnyrotten] #712757
06/01/10 11:59 PM
06/01/10 11:59 PM
Las Vegas
Las Vegas
Well the wheels are in motion already to get it freshened up. Looking at 6-8 weeks before the engine will be ready. Will post up some pics of some of the pieces if anyone is interested. I know I have been asked about the heads by a few guys.
As for heads, Indy's or Edelbrocks would be preferred at this point. I have parts to put a shortblock to gether with those heads. B1's would be nice but unless they come with pistons it wont be much help.
Re: BOOM! [Re: Al_Alguire] #712758
06/02/10 01:23 AM
06/02/10 01:23 AM
Renton Washington
Triple Threat Offline
Renton Washington
I got a set of CNC indys. (for a small block)
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: BOOM! [Re: Al_Alguire] #712759
06/02/10 08:42 AM
06/02/10 08:42 AM
tboomer Online work
tboomer  Online Work
Good luck on the rebuild,Al...
Re: BOOM! [Re: Chris'sBarracuda] #712760
06/03/10 02:00 AM
06/03/10 02:00 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
Thanks for the comments! Car is still in the working out bugs stage. Have had nothing but bad luck with motors so far. Hemi keeps eating push rods as was the case on sat night. Also have 622 wedge that has been unwilling to make more than 3 passes at a time without hurting somthing. Met and talked with Al at mopars at the strip. Qualified for Q-16 there with 622 , then head gasket issues. Al hope your year gets better! These things seem to come in streaks, Hopefully yours has reached the end, And goes uphill from here. Mike @ Comp Chassis
Re: BOOM! [Re: Comp Chassis 2] #712761
06/03/10 02:09 AM
06/03/10 02:09 AM
Glendale AZ
Glendale AZ
Sorry didn't get the quote in there. Was referring to the notch back cuda in Chris's post
Re: BOOM! [Re: Comp Chassis 2] #712762
06/03/10 10:11 AM
06/03/10 10:11 AM
Las Vegas
Las Vegas
Mike you need to throw up some pictures of that thing for everyone to see. It is a very nice car. Sporry to hear you are still having issues with it. How is the Daytona going? As for me, no big deal I knew I needed to freshen it up wash juts hoping to make it til after the year was over. It will be ready in a couple of months and we will be ready again.
Re: BOOM! [Re: Al_Alguire] #712763
06/03/10 07:56 PM
06/03/10 07:56 PM
Arizona
Chris'sBarracuda Offline
Arizona
Mike you need to throw up some pictures of that thing for everyone to see. It is a very nice car. Sorry to hear you are still having issues with it. How is the Daytona going? As for me, no big deal I knew I needed to freshen it up wash juts hoping to make it til after the year was over. It will be ready in a couple of months and we will be ready again.
I didn't have my camera ready when he was in the lanes or I would have taken some photos and posted them.. Very clean and nicely done..
Al.. You are a Veteran at this.. You will probably be ready by Bakersfield..
Hopefully the cylinders don't have any "Black Death" from Vegas..
Chris..
Re: BOOM! [Re: Chris'sBarracuda] #712764
06/04/10 12:13 AM
06/04/10 12:13 AM
Las Vegas
Las Vegas
Oh we will be ready by Bakersfield for sure. Only gonna be a matter of waiting for the rods and Isky to redo the lifters. Engine is apart and we are leaving in the AM to take it to Jason. Already put those wheels in motion.
Trying to decide if we are gonna dust off the other car to run a divisional or two just wait and focus on next year, and looking for another car. I have an oppourtunity to buy a nice 6.00 car but the price is kinda high and would have to sell the Cuda to make it happen. Leaning toward just getting it back up and runnign and focusing on next year and using Bakersfield and Vegas to get ready to try this again next year. Oh yeah the spare WILL be also made ready soon. Whether is makes it in the car is another question. I will miss Fallon because I was caught with my pants down this time.
