avs 650 or 800 carb for a stock 383HP????????? #712409
05/31/10 03:48 PM
05/31/10 03:48 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
which would you recommend??? price does not matter.its a pure stock 383HP 1969 RR eng
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: ngpSatellite] #712410
05/31/10 03:56 PM
05/31/10 03:56 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
650 for good street/mileage manners, 800 for more performance with minor mods (cam,intake,exhaust).
Save compression for a toss-up choice (mileage vs.
power), depending on the pump gas.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: HYPER8oSoNic] #712411
05/31/10 04:01 PM
05/31/10 04:01 PM
own private Idaho
N
N
own private Idaho
ahhhhh... hey thanks for the advice... just want a cruzer with little punch... leaning towards a 650..
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: ngpSatellite] #712412
05/31/10 04:06 PM
05/31/10 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
650 is how it was equipped originally , if it's stock stay with the 650
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: JohnRR] #712413
05/31/10 04:12 PM
05/31/10 04:12 PM
own private Idaho
N
N
own private Idaho
thats what I was thinking ... stock exhaust... the whole bit.. org pistons and cam... std bore the only diff is a eddy performer which is not a big upgrade??
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: ngpSatellite] #712414
05/31/10 09:50 PM
05/31/10 09:50 PM
Desert Tracker
Desert Tracker
Not too big of an upgrade, Saves you a few pounds
over the iron manifold. I believe the 69' RR
came through with 650 Carter AVS's, sort of like
the AFB, but the primary barrels are SLIGHTLY smaller than the secondary barrels. Not to be confused with the Carter Thermoquad!! All in all,
an easy carb to tune and maintain. A good rebuild/
jetting adjustment (for todays crappy gas) and some ignition timing changes, you're off and runnin'!!!
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: HYPER8oSoNic] #712415
05/31/10 09:55 PM
05/31/10 09:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
650
Sheldon
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: RUNCHARGER] #712416
05/31/10 10:10 PM
05/31/10 10:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
650 if the motor's bone stock.
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: DaytonaTurbo] #712417
06/01/10 12:28 AM
06/01/10 12:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
come ooon... stock 400s came with 850 cfms! ( so do same years 440s ) and 340s since 71/72 came with 800 cfms! carbs ( TQ )
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: NachoRT74] #712418
06/01/10 12:53 AM
06/01/10 12:53 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Squarebores & spreadbores react totally different from one another, so they can't be compaired as equals when your talking CFM, its apples too oranges, you can always get away with a larger CFM carb on a given app. if useing a spreadbore over a squarebore, i'm just talking vacuum controlled units, not DPers.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: joedust451] #712419
06/01/10 03:11 AM
06/01/10 03:11 AM
Desert Tracker
Desert Tracker
100%,
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: ngpSatellite] #712420
06/01/10 08:42 AM
06/01/10 08:42 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
People tend to overcarb. My 340 ET's best with a 650 Holley.
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: dustergirl340] #712421
06/01/10 12:13 PM
06/01/10 12:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I can say you can make a big mistake between a secondary vacuums or double pumper on an engine, but I don't think really between spreadbore or squarebore, or sequential over simultaneous... differences ? yes, they get diff responses ones over the others, then the quality of the piece and you must match the response you want with cam and timming, but not that big I think to "overcarb" just with CFM spec... I'm just being logical, not talking about the experience of course.
we got also 6packs on 340s ( 1000 cfms ), true just the center is the pumper
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: dustergirl340] #712422
06/01/10 01:57 PM
06/01/10 01:57 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
, so does mine, & it also runs cleaner & doesn't foul plugs, even if i jet it up.
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: joedust451] #712423
06/01/10 02:05 PM
06/01/10 02:05 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
650
ET wise I'd be willing to bet you could get more out of the 800 - but thats not your goal so 650 is your best bet!
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: DJVCuda] #712424
06/01/10 04:02 PM
06/01/10 04:02 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
if it helps any my hemi dynoed at 502 hp with a 750 dp on it and at 494 hp with an eddy 800 on it
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712425
06/02/10 11:21 PM
06/02/10 11:21 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Keep in mind boys and girls that the Thermoquads, Quadrajet, and AVS adjust their CFM's according to engine demand. That is why you can run those big carbs on little engines. Holleys don't do that.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: DJVCuda] #712426
06/02/10 11:34 PM
06/02/10 11:34 PM
Desert Tracker
Desert Tracker
True. BUT, you would have to improve the breathing
habits of the motor (headwork, headers, cam and intake).
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Rug_Trucker] #712427
06/02/10 11:42 PM
06/02/10 11:42 PM
Desert Tracker
Desert Tracker
Six packs are an example too.
Carters are more forgiving then mechanical
secondary Holleys. Although, the kick off the
line will be stronger with the DP. Vac sec Holleys
run strong too, if set right. AVS carbs are almost
foolproof.
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712428
06/02/10 11:44 PM
06/02/10 11:44 PM
Desert Tracker
Desert Tracker
What was the torque peaks on the motor?
