can this be repaired ? better pic. #711632
05/30/10 05:52 PM
05/30/10 05:52 PM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
had this suregrip in my car for a couple of years. Alot of gear clunk when shifting into gear. I believe someone ran it without lube. looks like one of the gears welded itself to the center shaft. this sheared the staking pin and the shaft began to spin with the gears. ate alot of material off suregrip housing. can it be repaired ?
Re: can this be repaired ? better pic. [Re: DOUGG] #711633
05/30/10 11:39 PM
05/30/10 11:39 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
No.
Re: can this be repaired ? better pic. [Re: DOUGG] #711634
05/30/10 11:42 PM
05/30/10 11:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: can this be repaired ? better pic. [Re: 69MOPE] #711635
05/30/10 11:49 PM
05/30/10 11:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No.
What he said , it's absolute garbage , but then again it's a cone type , GARBAGE by DESIGN ...
It MIGHT have been salvageable 2 years ago ...
Re: can this be repaired ? better pic. [Re: JohnRR] #711636
05/31/10 12:10 AM
05/31/10 12:10 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
It's toast, but on the bright side it would be a good time to upgrade to a clutch type sure-grip.
