Grilles and Head Lights
#711478
05/30/10 02:43 PM
05/30/10 02:43 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
This style grille/cowl/front end treatment pops up alot, is it aftermarket?
Alos, my headlight stalks on my 37 are cracked/broken. Are there aftermarket headlights available that look close as Im not retoring the truck.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Grilles and Head Lights
[Re: AZ_A12_BEE]
#711482
05/30/10 03:28 PM
05/30/10 03:28 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
The reason you see that front end so much is the 33-34 ford is the most copied car out there and so is the 32 ford, with all the steel cars and fiberglass cars being made they are like the first camaros, almost more around now than there was back then. go to any street rod show and you can see as many red or black 32,33-34 ford you want this is just my opinion and I don't mean any disrespect to anyone that owns or wants a 32-34 ford but I wouldn't want one for the same reason I would never own a camaro, it seams like everyone has one and I don't like to have what everyone else has now that truck you posted above is made up as that front end is car and the trucks used a front end more like a 32 ford in 33 and 34, that truck is pretty cool, I can see one done like that with a mopar body Ron...
[Re: Mopar Ron]
#711486
05/31/10 03:01 PM
05/31/10 03:01 PM
AZ_A12_BEE
Dreaming of the 808
My headlights are fine, its the mounting stalks that are cracked.
37 Plymouth PU
[Re: AZ_A12_BEE]
#711488
06/01/10 12:54 AM
06/01/10 12:54 AM
Mopar Ron
do your stands look like these??? that is what you need to use for the hood body lines to line up. they are pot metal, you might be able to have them welded up and then grind them down and save them. or if you use something else it would have to be something custom that would have to blend in to the body lines....
