Wheelie Bar/Chassis Questions #711213
05/30/10 08:15 AM
05/30/10 08:15 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I`m having a small issue with what I assume is the wheelie bars,more than the actual chassis set-up.
Problem started with still being wheels-up for the 1-2 shift. So lowered the wheeliebars and stiffen the springs on them.
That works SOME of the time. Now if the front gets higher than say 30in`s the car goes hard left AFTER its reach max height.
If I keep the w/bars low and stiff I can avert the height/left issue but on poor tracks like yesterday I blow the tires off since it nevers get up on the rear. So I took spring out of the w-bars . Hook improved but after the weather and track changed ,more power more hook.
Off in the grass we went.
I have video of yesterday{no I can`t figureout how to post} And what it does,leaves straight and square.After it reaches max height,goes left quickly.
Looks alot like a pulling tractor when he jabs one brake to correct on 2-wheels.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Post deleted by Defbob [Re: 6bblFLASH] #711214
05/30/10 11:02 AM
05/30/10 11:02 AM
Re: Wheelie Bar/Chassis Questions #711215
05/30/10 11:16 AM
05/30/10 11:16 AM
N.E. Ohio
N.E. Ohio
Ladderbars,coilovers,single adj. Aldon? shocks.
90/10 fronts,otherwise stock susp.
Not shooting for the moon,but want some airtime.
When it pulled big wheelies it went straight but 2nd gear was a constant issue.Smashed the pan several times trying to shift before it came down.
Lowered and stiffened the w-bars and that worked till it started spinning.
Re: Wheelie Bar/Chassis Questions *DELETED* [Re: 6bblFLASH] #711216
05/30/10 11:46 AM
05/30/10 11:46 AM
Post deleted by SUPERSTOCKRACER
Post deleted by Defbob [Re: 6bblFLASH] #711217
05/30/10 11:58 AM
05/30/10 11:58 AM
Re: Wheelie Bar/Chassis Questions #711218
05/30/10 12:00 PM
05/30/10 12:00 PM
N.E. Ohio
N.E. Ohio
Well I don`t think its just that simple. Are you saying of the 1,000`s of cars running w-bars,we ALL have our heads up our a-s?
My car has over 50% weight on the rear tires and makes good torq.Your car is a heavy automatic.
Apples to Oranges.
Re: Wheelie Bar/Chassis Questions #711219
05/30/10 12:19 PM
05/30/10 12:19 PM
N.E. Ohio
N.E. Ohio
Bar is in lowest hole,already limited some travel.
Will try more.
Next set of tires will be smaller and take out some hook.
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711220
05/30/10 12:20 PM
05/30/10 12:20 PM
SC
Greg Offline
Greg  Offline
SC
Dennis,
I would pm bondo bob or call him. I think he could help you out with whatever is causing your problems. some double adjustable afco's would help in tuning. I would call and setup a visit to his shop to check things out and maybe a trip to the track to help you tune on the car.
Re: Wheelie Bar/Chassis Questions [Re: Greg] #711221
05/30/10 12:22 PM
05/30/10 12:22 PM
N.E. Ohio
N.E. Ohio
Good advise,I`ll consider that
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711222
05/30/10 12:59 PM
05/30/10 12:59 PM
i wasnt going to reply.should have gone with my gut.
Re: Wheelie Bar/Chassis Questions #711223
05/30/10 06:46 PM
05/30/10 06:46 PM
IL
acme383 Offline
acme383  Offline
IL
superstockracer,
here's the video you've been looking for. now you can change your signature!
http://www.youtube.com/watch?v=2_OXcw0eqVI
"Beating the competition with a stick is just automatic!"
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711224
05/30/10 07:03 PM
05/30/10 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Up your rear tire pressure a 1/8 pound then check it
again... dont try to dead hook... if you get UP on
the tire some it'll 60' better and the front wont climb
as high..... DONT try steering the car with the WB
you can mildly assist it with them
Re: Wheelie Bar/Chassis Questions [Re: acme383] #711225
05/30/10 11:41 PM
05/30/10 11:41 PM
superstockracer,
who the heck are you?
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711226
05/31/10 01:01 AM
05/31/10 01:01 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
Have you tried staggering the height of the bars from one side to the other , most faster cars need one wheel higher than the other to keep from driving right on the bars. driving left I would say to much preload in rear suspention. Every car is different so its just something to ponder.
Re: Wheelie Bar/Chassis Questions [Re: Comp Chassis 2] #711227
05/31/10 09:16 AM
05/31/10 09:16 AM
N.E. Ohio
N.E. Ohio
W-bars are level now,right side pre-load was what I was thinking too.
Was on my list of things to check over,thanks
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711228
05/31/10 09:26 AM
05/31/10 09:26 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We had a similar problem years ago,and tried everything to correct it.We finally found that the chassis was flexing(twisting)we added a few more stiffening bars under the car at the frame connecters and ladder bar cross member and the problem went away.
Post deleted by Defbob [Re: B G Racing] #711229
05/31/10 11:16 AM
05/31/10 11:16 AM
Re: Wheelie Bar/Chassis Questions #711230
05/31/10 12:40 PM
05/31/10 12:40 PM
N.E. Ohio
N.E. Ohio
Heres a few shots
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711231
05/31/10 12:41 PM
05/31/10 12:41 PM
N.E. Ohio
N.E. Ohio
#2
Re: Wheelie Bar/Chassis Questions [Re: 6bblFLASH] #711232
05/31/10 12:41 PM
05/31/10 12:41 PM
N.E. Ohio
N.E. Ohio
#3
