Page 2 of 3 1 2 3
Re: Herb McCandless oiling tips for big block/Hemi [Re: AndyF] #7110
12/20/03 12:13 AM
12/20/03 12:13 AM
blocking off the oil to the driver's side is just a way to direct the oil pressure back to the main bearings rather than have it leak away around 8 lifters that don't need it.
For high perf street motors I usually block off the driver gallery but then drill a small hole (0.090) or so in the plug so that oil still flows, but at a reduced rate. I just haven't gotten comfortable with the idea of completely blocking off the lifter gallery on a street car.
do you have a good source for the plugs to do that, i have about 5 left and none to be found in south florida at all??? know of a place where i can order them?
In addition, blocking off the lifter galleys helps if you bend a push rod or a rocker adjuster backs off and a lifter jumps out, your oil pressure will not drop to zero.
that's if your luck enough for it to happen on that side of the block, LOL.
Re: Herb McCandless oiling tips for big block/Hemi #7111
12/20/03 12:02 PM
12/20/03 12:02 PM
okay, i guess nobody wants to share their source for the soft plugs. Hmmm.
Re: Herb McCandless oiling tips for big block/Hemi #7112
12/20/03 12:46 PM
12/20/03 12:46 PM
NC
440Jim Offline
440Jim  Offline
NC
What size are you looking for?
Back in with winter 2001/2002 when I pluged the driver's side oil galley in my block, I think I used a 37/64" deep cupped plug since the 19/32" wasn't to be found. I am running the 0.090" hole in it, and it hadn't moved when I checked it last. That was in Oct 2003 when I had a valve job done. The block had 110 passes in 2002, and 159 more in 2003 by Oct. I pulled a lifter and stuck a probe back to touch the plug.
Measure the hole size in the block, the 37/64" or a 15mm if available might do the trick.
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7113
12/20/03 01:12 PM
12/20/03 01:12 PM
i was looking for the 19/32. i think i tried a 37/64 in the last block and it was too loose to stay put. i guess i could alway's just run a ream through the hole and step up in size just slightly. thanks for the info.
Andy made it sound like the 19/32 were plentiful. i was hoping he would share his source. that might make things easier for people.
i am also a believer in running the plug as an orifice, instead of completely blocking it off. it sends more pressure where it's needed during start-up and then fills the lifter gallery for some lubrication there too.
Re: Herb McCandless oiling tips for big block/Hemi #7114
12/20/03 01:28 PM
12/20/03 01:28 PM
NC
440Jim Offline
440Jim  Offline
NC
Maybe my block had a new (or old) drill used at the factory and it cut a tight size. The other alternative is to drill and tap so the pipe plug can go back that far. But that requires drilling and tapping the outside plug one size bigger. A lot more work than just driving in the plug!
Or maybe the brand I get are oversize. I use a 1-3/4" on on trans speedo openings and the book says 1-49/64" is needed.
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7115
12/20/03 05:29 PM
12/20/03 05:29 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Expansion plugs link.
Look at www.motormite.com
Then click Dorman products.
Here are the exact plugs you need:
19/32" (0.59375") Dorman #555-009
And for the 727/904 Speedo plug 1-49/64"
Dorman #555-036
I got mine at Advance Auto Parts. Others should also carry them. John
Re: Herb McCandless oiling tips for big block/Hemi [Re: DusterW2] #7116
12/21/03 12:25 AM
12/21/03 12:25 AM
NC
440Jim Offline
440Jim  Offline
NC
Thanks John!
I will check tomorrow and get a couple for the drawer.
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7117
12/22/03 02:18 PM
12/22/03 02:18 PM
NC
440Jim Offline
440Jim  Offline
NC
My local Advance Auto didn't have the 19/32". The Autozone store didn't either and they both had the same assortment.
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7118
12/22/03 06:45 PM
12/22/03 06:45 PM
Hey Jim, I've got 9 of em. I can drop a couple in the mail if you'd like.
Max
Re: Herb McCandless oiling tips for big block/Hemi #7119
12/22/03 10:18 PM
12/22/03 10:18 PM
Max
well, i guess i see where i rate...
Re: Herb McCandless oiling tips for big block/Hemi #7120
12/22/03 10:37 PM
12/22/03 10:37 PM
I know Dram that was an oversight. but you already have some.But as you have 5, but if you'd like, I'll mail you one giving you six, then I'll give Jim 2, and I'll have six.
That's fair ain't it (except to Jim)
"Max"
Re: Herb McCandless oiling tips for big block/Hemi #7121
12/23/03 03:09 AM
12/23/03 03:09 AM
"Max"
Re: Herb McCandless oiling tips for big block/Hemi #7122
12/23/03 02:45 PM
12/23/03 02:45 PM
NC
440Jim Offline
440Jim  Offline
NC
Max, thanks for the offer.
I called around and my local NAPA had them in stock.
Their line is "CEP" and part number 219-3054 for the 19/32" plug. I stopped over during my lunch break and bought a few ($0.29 each) for my drawer/future use.
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7123
12/23/03 03:34 PM
12/23/03 03:34 PM
You are more than welcome.
Max
Post deleted by Defbob #7124
12/23/03 08:26 PM
12/23/03 08:26 PM
Re: Herb McCandless oiling tips for big block/Hemi #7125
12/23/03 09:22 PM
12/23/03 09:22 PM
milwaukee
superbird Offline
superbird  Offline
milwaukee
found the 19/32 freeze plug today but where does
one find the 10" drill bit? is drilling this out
something a guy can do at home in his garage?
if i want can i just go with the freeze plug
trick? not real comfortable drilling on a angle.
just picture the drill bit biteing hard and
snaping off and me haveing a big problem i do
not need! some what of a novice. only have enough
money to build this motor one time thanks in
advance brent
Re: Herb McCandless oiling tips for big block/Hemi [Re: superbird] #7126
12/23/03 11:57 PM
12/23/03 11:57 PM
Vacaville/ El Dorado Hills ,Ca
440FISH Offline
super gas
440FISH  Offline
super gas
anyone know of a good place for the 8-10” 9/32 drill bit?
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440FISH] #7127
12/24/03 12:51 AM
12/24/03 12:51 AM
why do you need a 9-10 inch drill bit???
Post deleted by Defbob [Re: 440FISH] #7128
12/24/03 05:28 AM
12/24/03 05:28 AM
Re: Herb McCandless oiling tips for big block/Hemi #7129
12/24/03 09:38 AM
12/24/03 09:38 AM
milwaukee
superbird Offline
superbird  Offline
milwaukee
Remove all five main caps. With an 8-10” 9/32 drill bit drill the oil passages from the top of the main saddle to the lifter galley on the passenger side of the block to 9/32
can you use i normal length drill bit?
Page 2 of 3 1 2 3
