Re: Shaker Bubble Color?
[Re: mccannix]
#71177
06/16/08 03:32 PM
06/16/08 03:32 PM
Thats a nice looking original scoop Mike, obviously a low mileage original.
Hi Terry, that scoop above is from Bob's car, i believe he said it was 15K original miles. Looks just like Mike Ross's even in the pics, Especially the "last One", and the one's I posted...
Notice how it is sprayed differently on the under side compared to the NOS one Scott posted...
That NOS one you just posted is definetely the DK/med Textured Argent... (same as use on the grilles).
Do you think that was sprayed by NAP or was someone else doing them by that time?
[Re: mccannix]
#71180
06/16/08 04:40 PM
06/16/08 04:40 PM
I may be missing something here but where is the picture Scott shows of the underside overspray. Are his pictures not of a bare scoop before anything was done.
the one he posted of the NOS scoop (the very first one) was on ebay.
here is the underside.
[Re: ScottSmith_Harms]
#71183
06/16/08 06:38 PM
06/16/08 06:38 PM
The NOS example shown above was painted differently than every production line unit I've seen, most likely primed and painted using a different process
The one off Bobs' 15k is the only one i havever seen withat much lopsided red overspray, the way i have seen them is: it is fairly even and not as noticeable mid shaker...
Which hole/ or where was the hanging hook located on the NOS one posted above, and where was it on Bobs scoop?
#71189
06/16/08 07:36 PM
06/16/08 07:36 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
This is a 71 production line piece (it was a black Organosol bubble in original paint). Looks like two hooks hung this one as well.
[Re: mccannix]
#71193
06/16/08 08:27 PM
06/16/08 08:27 PM
Regarding the underside of Chris' scoop, I have never seen an overspray pattern like that underneath one....looks like someone got trigger happy
check out the spray pattern of the NOS argent scoop bottom (CB's), to that of the OE red one Scott posted. Similar spray pattern location/saturation etc. Done by same guy?
Guess if i had to spray a 1000 of them a hanging system would be the way to go, but it sure looks like a lot of inconsistency from one to another. (yes i have never done one that way so guess mine arent "OE" correct, except in colors, The one on the left is an untouched NOS black scoop)).
One more thing to add to the issca (??) judging standards.
#71194
06/16/08 09:25 PM
06/16/08 09:25 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I wasn't pointing fingers concerning your work meeting OE standards Mike, (hopefully you know I've always given your work high praises) just trying to get them to the next level which it appears to me there is a little room for.
As far as ICCA "standards" there are none really, it's an ever evolving set of guidlines which changes as new information is obtained and added. In the case of the details on the undersides of Shaker bubbles, yes, they are scrutinized by at least 2 judges and decisions about correctness are made.
#71195
06/16/08 10:39 PM
06/16/08 10:39 PM
Thx Scott i was dogging myself...
i agree there is a lot of "room" based on this knowlegde, but i doubt there is the room for the difference in price vs the time, etc...
now if I start seeing every OE judged shaker come my way... then it wouldnt be that hard to get "sloppier" with the red primer....
#71196
06/17/08 02:37 AM
06/17/08 02:37 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Excuse me for being a little off topic Scott but the above quote reminded me of a couple of instances that were expressed by two different customers of mine. Both guys (different shows and didn't know each other) had said that their voltage regulators were given deductions in the ICCA judging. These were two totally unrelated situations keep in mind. One gentleman said his regulator had been given a deduction because it was too nice and did not exhibit the "necessary raw" appearance of those that were factory or NOS. The other gentleman said his regulator was given a deduction because it had some scuffs on it (his unit was completely NOS) and was not in good enough condition. I thought that was a contrary, no win situation in the world of judging. Either one could have been exemplary of a factory original! I only bring this up because ANY part that is judged can express or represent a range of different variations and still be correct. Don't you think (as evident in my example above ) that only acknowledging a narrow acceptance or view towards a multi faceted subject, will only take away from examples that could be 100% correct? And what about the participant who DOES have a correct version but the judges knowledge hasn't reached that level of correct awareness?
