Re: K member ID question
[Re: Kern Dog]
#711066
05/30/10 12:41 PM
05/30/10 12:41 PM
Posts: 484 PORT ALBERNI B.C. CANADA
71DemonRON
This is a 69' b-body with an E-body K member
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter 1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
[Re: 71DemonRON]
#711067
05/30/10 12:44 PM
05/30/10 12:44 PM
71DemonRON
This is an E-body with an E-body OR a 71-72 B-body K member, steering shaft straight in line with the steering box.
1971 Demon drag car
2004 SX 2.0
[Re: 71DemonRON]
#711068
05/30/10 09:06 PM
05/30/10 09:06 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Beginning at some point in 1970, K-members came with an identification coin. The identification coins are spot welded to the K-frame and have a two digit number on them which is the last two digits of the K-member part number. For example, a 1971 E-Body K-frame is Chrysler part number #3583074. So the ID coin would be 74. Notice in the image below that the K-frame ID'd "74", fits 70-71 E-Body 383/440 w/skid plate and 71 B and E-Body 318/340/383/440 w/skid plate. The motor books will tell you that ALL 1966-to-1974 K-members will interchange. This is partly true as the K-members will bolt in, but the steering angle/pitch is what will bite you if you don't get the correct K-member for your application.
[Re: Kern Dog]
#711070
05/31/10 12:23 AM
05/31/10 12:23 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
I can't see much difference between the steering box angles. Maybe its me. Could you help an old guy out and explain?
The steering shaft is angled to the left in this picture of a 70E-body K in a 69 B-body.
[Re: IMGTX]
#711074
05/31/10 02:14 PM
05/31/10 02:14 PM
autoxcuda
So Cal
Just a few more Fyi's from my experience.
The ID coins are hit or miss. Out of about 10 K-frames I have only 2 have the coins.
The angle has been measured to about 3.5 degrees. This was probably within the crappy tolerances the factory used in my opinion so it even if you get a 70 B in an E or vise verse it should be fine. The coupler will more than compensate for that. As long as it doesn't bind your OK.
I agree, you'll be fine from a steering shaft deal. And also about the coin deal.
But if you are running headers there may be issues. I'd check with TTI first about running E-body K frame in a 70 down B-body and vice versa.
[Re: 71DemonRON]
#2149728
09/07/16 04:43 PM
09/07/16 04:43 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Bring this one back from the closet.. In the process of restoring my '70 Superbird, I have a k-member I was suspicious about. After reading this thread via search, I came to realize the geometry might be off. It seems I have a 71 #3583100 k-member since it appears I have a "00" on the tag stamped on the k-member. I know the proper k-member is #3466479, with a "79" on the welded tag. Can this 71 k-member be used? My buddy has the ability to reweld a reproduction ID tag on my current k-member. Or, I can try to trade it for a proper '70 k-member. After all, mine is more rare..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: JohnRR]
#2150208
09/08/16 09:11 AM
09/08/16 09:11 AM
hemi68charger
Houston, Tx
Can it be used , yes, but the steering box angle will be off like in the picture autoxcuda posted above. Thanks guys... I'd prefer not to have geometry issues... I'm sure I can sell the one I have and pick up a proper "79" k-member.
[Re: hemi68charger]
#2150219
09/08/16 09:41 AM
09/08/16 09:41 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Can it be used , yes, but the steering box angle will be off like in the picture autoxcuda posted above. Thanks guys... I'd prefer not to have geometry issues... I'm sure I can sell the one I have and pick up a proper "79" k-member. the only geometry issue would be between the steering box and and steering column , I don't know what the angle is on a correct cK memeber and I don't know is there isa slight bind in the setup above , if it had something like a borgensen u jointo between the box and the column it would be fine. But I know that is not an option. You shouldn't have a hard time selling that one and getting the right K. Even if you can find a real nice 70 K without a skidplate you can always add the fresh repop skidplate, which won't be bashed in because the 70 plate is rather fragile in my opinion, and the repop coin.
[Re: 71DemonRON]
#2150235
09/08/16 10:42 AM
09/08/16 10:42 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I thought I had an engineering drawing talking about the angle but I cant seem to find it. I did find this one that seems to show a shim on one side of the gear box.
Careful, your character's showing!
