K member ID question #711060
05/29/10 09:35 PM
05/29/10 09:35 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline OP
I need a replacement K member for my 1971 Challenger. I picked up a decent one for $40.00 The guy said he got it from a local wrecker years ago, they told him it was from a 1974 Barracuda. It has 049M142 clearly stamped on the top side with a 7 also stamped on the top side, on the bottom it has what looks like 646141 ? It is a V8 k member with the 70 & up sway bar mounting holes. The only E-body that I can remember this wrecker having in the last 20 years is a 1971 challenger that had a 1970 grill. I checked the tech archives, no matches. Can anyone ID this k member ? THANKS
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: K member ID question [Re: 71DemonRON] #711061
05/30/10 01:14 AM
05/30/10 01:14 AM
IMGTX Offline
IMGTX  Offline
If it really did come from a 74 there will be a weird bracket on the motor mount. Drivers side I think but don't chisel it in stone.
It was as if Ma Mopar had an idea but never implemented it because I have never seen anything bolted to them but they are only on the 74 E-bodies.
Go figure.
Re: K member ID question [Re: 71DemonRON] #711062
05/30/10 01:20 AM
05/30/10 01:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A local Mopar Guru told me that the 70-72 B and 70-74 E body cars used the same V8 non HEMI K member. I guess there could be a few subtle differences, but they are supposed to physically fit and function the same.
Re: K member ID question [Re: Kern Dog] #711063
05/30/10 01:41 AM
05/30/10 01:41 AM
IMGTX Offline
IMGTX  Offline
Yes 70 B's will fit with small differences in the steering box angle. 71-72 are the same.
Re: K member ID question [Re: IMGTX] #711064
05/30/10 02:24 AM
05/30/10 02:24 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Re: K member ID question [Re: IMGTX] #711065
05/30/10 03:26 AM
05/30/10 03:26 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Steering box angle? Tell me more! I have a 70 Charger. WAS a 318, now a 440. Stock K frame. What is the difference you refer to? Is the angle directed to left or right OR up and down?
Re: K member ID question [Re: Kern Dog] #711066
05/30/10 12:41 PM
05/30/10 12:41 PM
This is a 69' b-body with an E-body K member
1971 Demon drag car
2004 SX 2.0
Re: K member ID question [Re: 71DemonRON] #711067
05/30/10 12:44 PM
05/30/10 12:44 PM
This is an E-body with an E-body OR a 71-72 B-body K member, steering shaft straight in line with the steering box.
1971 Demon drag car
2004 SX 2.0
Re: K member ID question [Re: 71DemonRON] #711068
05/30/10 09:06 PM
05/30/10 09:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Beginning at some point in 1970, K-members came with an identification coin. The identification coins are spot welded to the K-frame and have a two digit number on them which is the last two digits of the K-member part number.
For example, a 1971 E-Body K-frame is Chrysler part number #3583074. So the ID coin would be 74.
Notice in the image below that the K-frame ID'd "74", fits 70-71 E-Body 383/440 w/skid plate and 71 B and E-Body 318/340/383/440 w/skid plate.
The motor books will tell you that ALL 1966-to-1974 K-members will interchange. This is partly true as the K-members will bolt in, but the steering angle/pitch is what will bite you if you don't get the correct K-member for your application.
Re: K member ID question [Re: 71DemonRON] #711069
05/31/10 12:19 AM
05/31/10 12:19 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I can't see much difference between the steering box angles. Maybe its me. Could you help an old guy out and explain?
Re: K member ID question [Re: Kern Dog] #711070
05/31/10 12:23 AM
05/31/10 12:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The steering shaft is angled to the left in this picture of a 70E-body K in a 69 B-body.
Re: K member ID question [Re: autoxcuda] #711071
05/31/10 12:29 AM
05/31/10 12:29 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
AUTOXCUDA to the rescue again! You are a great asset to this forum. Thank you again. I see the difference now.
Re: K member ID question [Re: CompSyn] #711072
05/31/10 11:26 AM
05/31/10 11:26 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and sway bar was attached somehow diff since 70
Re: K member ID question [Re: 71DemonRON] #711073
05/31/10 12:00 PM
05/31/10 12:00 PM
IMGTX Offline
IMGTX  Offline
Just a few more Fyi's from my experience.
The ID coins are hit or miss. Out of about 10 K-frames I have only 2 have the coins.
The angle has been measured to about 3.5 degrees. This was probably within the crappy tolerances the factory used in my opinion so it even if you get a 70 B in an E or vise verse it should be fine. The coupler will more than compensate for that. As long as it doesn't bind your OK.
Re: K member ID question [Re: IMGTX] #711074
05/31/10 02:14 PM
05/31/10 02:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree, you'll be fine from a steering shaft deal. And also about the coin deal.
But if you are running headers there may be issues. I'd check with TTI first about running E-body K frame in a 70 down B-body and vice versa.
Re: K member ID question [Re: 71DemonRON] #2149728
09/07/16 04:43 PM
09/07/16 04:43 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Bring this one back from the closet..
In the process of restoring my '70 Superbird, I have a k-member I was suspicious about. After reading this thread via search, I came to realize the geometry might be off. It seems I have a 71 #3583100 k-member since it appears I have a "00" on the tag stamped on the k-member. I know the proper k-member is #3466479, with a "79" on the welded tag. Can this 71 k-member be used? My buddy has the ability to reweld a reproduction ID tag on my current k-member. Or, I can try to trade it for a proper '70 k-member. After all, mine is more rare.. grin
Troy
Houston Mopar Connection Club
Re: K member ID question [Re: 71DemonRON] #2150016
09/07/16 11:17 PM
09/07/16 11:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can it be used , yes, but the steering box angle will be off like in the picture autoxcuda posted above.
Re: K member ID question [Re: JohnRR] #2150208
09/08/16 09:11 AM
09/08/16 09:11 AM
Houston, Tx
Houston, Tx
Thanks guys... I'd prefer not to have geometry issues... I'm sure I can sell the one I have and pick up a proper "79" k-member.
Troy
Re: K member ID question [Re: hemi68charger] #2150219
09/08/16 09:41 AM
09/08/16 09:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the only geometry issue would be between the steering box and and steering column , I don't know what the angle is on a correct cK memeber and I don't know is there isa slight bind in the setup above , if it had something like a borgensen u jointo between the box and the column it would be fine. But I know that is not an option.
You shouldn't have a hard time selling that one and getting the right K. Even if you can find a real nice 70 K without a skidplate you can always add the fresh repop skidplate, which won't be bashed in because the 70 plate is rather fragile in my opinion, and the repop coin.
Re: K member ID question [Re: 71DemonRON] #2150235
09/08/16 10:42 AM
09/08/16 10:42 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I thought I had an engineering drawing talking about the angle but I cant seem to find it. I did find this one that seems to show a shim on one side of the gear box.
Careful, your character's showing!
