After reading some good recent posts about tuning carbs and setting timing, I thought I'd give it a shot, so I bought a vacuum gauge today. Wasn't easy to find either - I think I got the only one in the city.
Anyway, when I took it out of the package, I noticed that the needle was not on zero. You can see it in the photo.
The second photo (I'll post in a minute) shows the back of the instruction sheet, and it says that you can remove the lens, then remove and reposition the needle.
Has anyone ever had to do this? Did I just get a gauge that's been knocked around on the shelf over the years?
Also, the instruction sheet calls it a "bourbon" tube vacuum gauge, but I looked it up and I think it is supposed to be "bourdon".
