Identifying INDY rocker arm ratio? #710839
05/29/10 02:50 PM
05/29/10 02:50 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Were trying to order some T&D rockers after busting an INDY rocker but unsure of the ratio. Is there an easy way of finding out? We dont have much info on this motor. The heads are 440-EZ 295'S and have black INDY rockers on them.
Re: Identifying INDY rocker arm ratio? [Re: blown360] #710840
05/29/10 03:05 PM
05/29/10 03:05 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
black 1.5 blue 1.6... some will verify this im sure though....
Mopar Performance
Re: Identifying INDY rocker arm ratio? [Re: moparniac] #710841
05/29/10 06:46 PM
05/29/10 06:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Re: Identifying INDY rocker arm ratio? [Re: blown360] #710842
05/29/10 10:15 PM
05/29/10 10:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you knw the cam lobe lift you can set the lash at zero and open the valve all the way by turning the cranksahft with a dial indicator on the retainer(make sure the dial indicator stem is on the same angle as the valve stem from left to right and front to back)and take the net valve lift and do the math. IE .400 lobe lift times 1.5 = .600, 1.6 times .400 = .640. Don't be suprised if the ratio are off some
Re: Identifying INDY rocker arm ratio? [Re: Cab_Burge] #710843
06/02/10 11:55 AM
06/02/10 11:55 AM
WI
mopar873 Offline
mopar873  Offline
WI
Sledgehammer is correct. Indy Blacks are 1.5.
