aluminum driveshaft #710488
05/29/10 10:26 AM
05/29/10 10:26 AM
Central New York
slippery440 Offline OP
Crybaby440
Crybaby440
Central New York
My buddie was out in the salvage yard looking for a big yoke input shaft for a 727. He found a 1999 2500 series van with a alum. driveshaft and it had the big yokes.We test fit the input shaft and that worked and the universals work. Will this driveshaft hold up in a mid 10 secound 3300 pound drag car?
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: aluminum driveshaft [Re: slippery440] #710489
05/29/10 11:46 AM
05/29/10 11:46 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes,
Re: aluminum driveshaft [Re: Challenger 1] #710490
05/29/10 12:59 PM
05/29/10 12:59 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Gary, do you know that for sure? Victor what is the application you're using it in? i will be needing a shaft and it would be nice to get one from a bone yard as opposed to having a new one made.
Re: aluminum driveshaft [Re: jamesc] #710491
05/29/10 01:21 PM
05/29/10 01:21 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
onced used an alum. shaft out of a '97 ram. zero problems behind 600 hp big block, 727, 3200 lb car.
Re: aluminum driveshaft [Re: jughed] #710492
05/29/10 02:34 PM
05/29/10 02:34 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I have Aluminum Drive shaft in my car. 3100Lb Super Street car. 512 cubic inch motor that makes 800 hp and over 700 tq. I bought the tube at the salvage yard and had it shortened to the correct length. Mine is out of a Chev 1/2 Ton. The car has gone 9.50 at altitude with no issues.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: aluminum driveshaft [Re: jamesc] #710493
05/29/10 03:35 PM
05/29/10 03:35 PM
Central New York
Crybaby440
Crybaby440
Central New York
James its a 1977 Aspen that makes 550 to 600 horse and weighs 3300 pounds.I think this is the way to go.The weight differance is alot. May need a bigger diameter driveshaft loop.He scored his fo 50 bucks.More that the salvage yard would of got from scrap.
Re: aluminum driveshaft [Re: slippery440] #710494
06/06/10 07:05 AM
06/06/10 07:05 AM
jamesc Offline
jamesc  Offline
anybody know which u joints these shafts use?
Re: aluminum driveshaft [Re: jamesc] #710495
06/06/10 09:30 AM
06/06/10 09:30 AM
Central New York
Crybaby440
Crybaby440
Central New York
We measured and its the big universal.3 5/8s and the caps are 1 1/8.
Re: aluminum driveshaft [Re: slippery440] #710496
06/06/10 01:31 PM
06/06/10 01:31 PM
jamesc Offline
jamesc  Offline
OK thanks, that would make them the 1350 i assume.
Re: aluminum driveshaft [Re: jamesc] #710497
06/06/10 02:19 PM
06/06/10 02:19 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
The drivehsaft in my car is a alum one from the boneyard out of a Crown vic police car. It has the 1350 big u joint ends on it and i had a driveshaft shop cut it down and balance it for 80.00 and he said that it should easily hold 1000 hp.. It has worked great for me and i have 180. total investment in it!!!!!!!!!!!
www.sikosracing.net Heads up Drag racing
Re: aluminum driveshaft [Re: moparmattkos] #710498
06/06/10 10:40 PM
06/06/10 10:40 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have ck'd many of those cop car shafts and I have yet to find one with 1350 joints. All I've ck'd had the 1330 joints in it.
Post deleted by Defbob [Re: jamesc] #710499
06/06/10 11:06 PM
06/06/10 11:06 PM
Re: aluminum driveshaft #710500
06/06/10 11:33 PM
06/06/10 11:33 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
Thanks Fred, I am going to check these out.
Re: aluminum driveshaft [Re: slippery440] #710501
06/06/10 11:48 PM
06/06/10 11:48 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
I have a aluminun drive shaft out of Ford victoria shortened to correct length. I replaced the imput shaft. The car runs low 10 seconds at 3000 pounds
Re: aluminum driveshaft [Re: Blucuda413] #710502
06/06/10 11:54 PM
06/06/10 11:54 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Mine is out a police car and it has a 1330
Post deleted by Defbob [Re: cbarracuda] #710503
06/07/10 12:42 AM
06/07/10 12:42 AM
Re: aluminum driveshaft #710504
06/07/10 03:49 PM
06/07/10 03:49 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I got one of the Spicer aluminum driveshafts from Muscle Motorsports. Appears to be a quailty piece. I believe they are 3.5" shafts. Even got it at the correct length that I needed.
FYI, upgrading to 1350 yokes may add some additional $$ to the overall cost if you go this route.
Re: aluminum driveshaft [Re: cruzin] #710505
06/07/10 04:09 PM
06/07/10 04:09 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
crown vic police car shaft here to, I use a 1330/7290 conversion joint, I paid $10.00 for my shaft and $75.00 for a cut and balance.
Re: aluminum driveshaft [Re: Blucuda413] #710506
06/07/10 05:13 PM
06/07/10 05:13 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
check the vans also 1350 joints.
$75 out the door
or if cutting u can use the f-250/dana shafts just do the front u-eie
Re: aluminum driveshaft [Re: HemiGreg] #710507
06/07/10 08:56 PM
06/07/10 08:56 PM
412 SB Duster Offline
Has anyone just changed the drive shaft and picked up any ET.
