Which Transmission Speedo Pinion Gear??? #710371
05/29/10 01:02 AM
05/29/10 01:02 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have a 69 charger 383 w/ 727 auto. It has 255/60 15 on the rear. Which speedo pinion gear do i need?
Re: Which Transmission Speedo Pinion Gear??? [Re: lukendan] #710372
05/29/10 01:04 AM
05/29/10 01:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You will need to post the gear ratio for the rear end also.
Re: Which Transmission Speedo Pinion Gear??? [Re: Alaskan_TA] #710373
05/29/10 01:11 AM
05/29/10 01:11 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
oops. The rear end is a 8 3/4 Sure-Grip w/ 3.23
Re: Which Transmission Speedo Pinion Gear??? [Re: lukendan] #710374
05/29/10 01:13 AM
05/29/10 01:13 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I had to do a little digging, look here;
http://www.moparts.org/Tech/tech/pages/speedo.html
Re: Which Transmission Speedo Pinion Gear??? [Re: Alaskan_TA] #710375
05/29/10 01:20 AM
05/29/10 01:20 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
31 teeth. Thx a bunch. Have a great weekend!!!
