727 trans #710216
05/28/10 09:29 PM
05/28/10 09:29 PM
ohio
silverhemiboy Offline OP
ohio
I'm looking for a little advice. I'm getting a vibration and it seems like something is loose and hitting the floor board. My mechanic buddy looked underneath and felt that the drive shaft as it goes into the back of the trans was moving up and down to much. It seemed like the driveshaft could be pushed up from a static position approx a half inch. He thought a seal or bearing needed to be replaced in the trans. Any thoughts? This is in my 68 hemi RR. Best regards.
Re: 727 trans [Re: silverhemiboy] #710217
05/28/10 09:32 PM
05/28/10 09:32 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
There's a bushing in the tail shaft extension housing. Probably needs to be replaced.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 727 trans [Re: johnedod] #710218
05/28/10 10:58 PM
05/28/10 10:58 PM
scratchnfotraction Offline
tranz mount
tail shaft bushing
both..
Re: 727 trans [Re: silverhemiboy] #710219
05/29/10 01:09 AM
05/29/10 01:09 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
NO movement of the tail housing as it is bolted to the crossmember ?
As is said above .... roger-that - tail-shaft bushing .... but ONE-HALF-INCH movement ? ..... the bushing would have to be totally WIPED OUT .... or missing completely.
Re: 727 trans [Re: dOoC] #710220
05/29/10 09:05 AM
05/29/10 09:05 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Could be U joint and bushin combo also.We had a 67 come in a few years ago that the bushing actually came out.Installed a new one and joint and all was well.Pull the shaft and check the joint and bushing.Rocky
Chrysler Firepower
Re: 727 trans [Re: therocks] #710221
05/29/10 09:51 AM
05/29/10 09:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How far does the yoke stick out of the trans? That kind of movement coild be from the driveshaft being too short.
