removing surface rust? #709986
05/28/10 01:15 PM
05/28/10 01:15 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
many years before i bought my desoto someone removed all the paint, the entire car is surface rust. without blasting or dipping whats the best way to get the metal paintable?
Re: removing surface rust? [Re: 65rbdodge] #709987
05/30/10 09:18 PM
05/30/10 09:18 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
the scotchbrite scrubby pad thingies with abrasive embedded work pretty good. (that's a highly technical description. I'm not sure what they're called in layman's terms)
Re: removing surface rust? [Re: FuryUs] #709988
05/31/10 09:51 AM
05/31/10 09:51 AM
moparx Offline
moparx  Offline
after that, there will probably be some "black looking" specks remaining [not talking pits here], which is still rust, that should be treated with some sort of "acid etching/neautralizing[?]" stuff to effectivly kill the rust before resorting to the primer/etching coating of choice. i have seen instances where bare metal [with the "specks"]was coated with etching primer/topcoat only to have paint problems appear because those "specks" were not dealt with. just so ya know........
Re: removing surface rust? [Re: moparx] #709989
05/31/10 10:33 AM
05/31/10 10:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
prep-sol or similar will take care of the specks, it's essentially dilute phosphoric acid.
Don't be the exception.
