440 start up problem
#709876
05/28/10 11:06 AM
05/28/10 11:06 AM
Posts: 134 Anchorage,AK
AK_JH27
Anchorage,AK
fired up my 440 for the first time last night, started fine and about 7 minutes into it, Oil started pouring out the drivers side valve cover. so I had to shut it down, what I found was the gasket on the cover had folded over on itself which caused a good size hole, very hard to miss since its so close to the brake booster , I will thank my brother later, he is one who "tigthen the cover down" once fixed i started it again and let it run for another 18 mins and had to shut it down again, this time it was running very hot, not sure if it was related to the first shutdown, it was getting hot then too. you could hear water boiling inside the rad hose.
my question: Think I did any damage to the cam or engine by shutting it down twice.
I let it sit for about an hour to cool and it started right up and ran fine. but this time it seemed to have a knock like pistion slap going on, i opened the thottle a bit and it went away.
kinda sucks, I seemed to be chasing all the little gemlins lately with this car.
Re: 440 start up problem
[Re: AK_JH27]
#709878
05/28/10 11:24 AM
05/28/10 11:24 AM
RapidRobert
Was this an initial cam breakin? You would want the stat out & was the timing in the ballpark? How hot?
[Re: RapidRobert]
#709880
05/28/10 12:52 PM
05/28/10 12:52 PM
AK_JH27
Anchorage,AK
yes it was inital break in, I have about 24mins on the cam now, think that might be enough for the break in period? i was using the factory temp gauage for the heat, the needle was just off to the left of //h and was holding pretty steady, it did creep towards the "H" a few times, but man it felt really hot. I know that new motors run hot but this seemed more then usual
timing was is in the ballpark, I hit the key the first time and it started and ran perfectly, I hit it with a timing gun and was sittingat about 15 degrees BTDC.
[Re: ireland383]
#709885
05/28/10 11:47 PM
05/28/10 11:47 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Should have had more than 15 degrees at the RPM you would break a cam in at.
So I would say it is retarded and that would run hotter.
I want my fair share
