SUPERCHARGER STORE #709856
05/28/10 10:32 AM
05/28/10 10:32 AM
Maryland
cudaboone Offline OP
Maryland
Is anyone running a procharger F-1 or similar on a E body Hemi cuda. I would like to put one on my 528. Just asking because there is so much info out there, but is very technical. I am wanting the water injection system because of the 10.75 compression. Talking to Bob at the supercharger store, it is going to cost around 8500 with power steering.
Re: SUPERCHARGER STORE [Re: cudaboone] #709857
05/28/10 11:55 AM
05/28/10 11:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No experience with prochargers here, but you should try posting this in the forced induction sub-forum instead of the q&a section.
What I do know of the F-1's is they are capable of putting out a TON of horsepower. What are your goals for your 528?
Re: SUPERCHARGER STORE [Re: DaytonaTurbo] #709858
05/28/10 02:57 PM
05/28/10 02:57 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
buy it, bolt it on, do wheelies....end of story
Re: SUPERCHARGER STORE [Re: DaytonaTurbo] #709859
05/28/10 04:42 PM
05/28/10 04:42 PM
Maryland
Maryland
It' just a weekend street car. Never leaves garage unless it is sunny and no rain in forecast.
Post deleted by Defbob [Re: cudaboone] #709860
05/28/10 11:10 PM
05/28/10 11:10 PM
Re: SUPERCHARGER STORE #709861
05/29/10 12:02 AM
05/29/10 12:02 AM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
then just buy the decals put them on the windows and save the money for wild women and liquer
LOLOLOLOL Now thats the best advice ive ever heard given for free!!!
www.sikosracing.net Heads up Drag racing
Re: SUPERCHARGER STORE [Re: moparmattkos] #709862
05/29/10 08:24 AM
05/29/10 08:24 AM
Maryland
Maryland
I know it sounds like lol but is something i want to try. Looking under my hood, i can't imagine how i would ever fit that thing in there. I see that people send pictures. How do you do the pictures?
Re: SUPERCHARGER STORE [Re: cudaboone] #709863
05/29/10 09:48 AM
05/29/10 09:48 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I built this Hemi for a 70 E-Body and the drivers side front fender had to be "dimpled" to clear the blower. By dimpled I mean a dinner plate size piece removed and a dish shaped piece welded back in. This was not a problem since the car was not painted yet, but if the car was already painted you would have an issue.
Re: SUPERCHARGER STORE [Re: Mopar_Rich] #709864
05/29/10 11:09 AM
05/29/10 11:09 AM
Maryland
Maryland
thats a beatiful engine. looks a lot like mine. If i could figure out how to send pics i would send one. What size carb and intake. I have the indy dominator intake and 1050 holley dominator carb. Anyway, i need to get my carb lower for clearance. carb diameter to big for the intake from procharger. Will have to go smaller intake and carb. What is your compression and how much boost are you using. Bob from the supercharger store did not mention that i would have to cut the inner fender? Car was just painted last year. Also, i would hate to have to remove the engine for modifications. Do you have the water injection and what procharger is it? that is
Re: SUPERCHARGER STORE [Re: cudaboone] #709865
05/29/10 01:07 PM
05/29/10 01:07 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
This is a 472" street motor with 9:1 static, at 8 lbs on 91 octane pump gas it made 825 HP. The carb is a 750 from CSU. With different pulleys at 13 lbs with 98 octane it made right at 1000 HP. No water injection. It's an F1.
I saw no way to do it without modifying the inner fender. The air cleaner is already slammed against the valve cover.
Re: SUPERCHARGER STORE [Re: Mopar_Rich] #709866
05/29/10 03:37 PM
05/29/10 03:37 PM
Maryland
Maryland
What is the difference between the D1SC and the F1? How do you determine when you need water injection to keep from burning pistons? The more i read the more confused i get. Check the picture. You can see how tight it is now.
6009308-cudapictures.mht (292 downloads)
