W2 QUESTION #709639
05/27/10 10:20 PM
05/27/10 10:20 PM
Peru
cbarracuda Offline OP
Peru
to get quench with flat top piston, is it posible to mill to get close chamber? will it weaken the head?
Re: W2 QUESTION [Re: cbarracuda] #709640
05/27/10 10:39 PM
05/27/10 10:39 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Most w2's can be milled to close chamber, but check the deck thickness first. The intake will need cut a good bit to match the heads. Also, you'll be around 13:1 compression if you mill the heads that much. - Andy
Re: W2 QUESTION [Re: 340_Dart] #709641
05/28/10 09:43 PM
05/28/10 09:43 PM
Peru
Peru
thanks andy
Re: W2 QUESTION [Re: cbarracuda] #709642
05/28/10 09:54 PM
05/28/10 09:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a pair of W-2s cut down to closed chambers
no problems.... I believe I took .090 off
