440 Source Dampers/Balancer...anyone use them #709620
05/27/10 10:05 PM
05/27/10 10:05 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Anyone use this vibration damper. SFI approved.
Don't care to hear 440 source bashing just a take on this damper
440 source damper link
THNX!!!
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709621
05/27/10 10:23 PM
05/27/10 10:23 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I've heard nothing good about fluid type balancers.
I used a professional products powerforce plus SFI dampner on mine.
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709622
05/27/10 10:34 PM
05/27/10 10:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have one. No complaints but haven't put it on the motor yet. Don't expect a "show" chrome finish - I imagine chrome was cheaper than powdercoat.
Re: 440 Source Dampers/Balancer...anyone use them [Re: Stanton] #709623
05/27/10 11:17 PM
05/27/10 11:17 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I have one. It's on the motor. Motor's been dynoed to at least 5200 rpm. Didn't explode.
Motor's in the car, but hasn't been fired since.
Don't know what more to say. Except that the March pulley kit works with it. Crank pulley fits fine in the recess in the damper hub. Same thickness in hub as factory unit. For perfect water pump pulley alignment, I had to put some thin washers behind the WP pulley hub. May have been the WP and WP housing, MP aluminum stuff. Alternator lined up okay.
Re: 440 Source Dampers/Balancer...anyone use them [Re: MoparMarq] #709624
05/27/10 11:24 PM
05/27/10 11:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
We spun mine to 7400. Any more than that and I would recomend something like an ATI.
Here's a couple pics.
Re: 440 Source Dampers/Balancer...anyone use them [Re: WILD BILL] #709625
05/27/10 11:28 PM
05/27/10 11:28 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Pretty nice looking balancer Bill.. How hard did it go on the crank?
Re: 440 Source Dampers/Balancer...anyone use them [Re: 52savoy] #709626
05/27/10 11:32 PM
05/27/10 11:32 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't recall having any issues putting it on but we did use a dampner tool to install it so I guess it went on easy.
I can tell you we didn't have to fix any interference issus that I remember.
Only thing to we did was remove all the screws and put Loc Tite on them. Scott says he has seen them back off so he Loc Tites all of them now from the start.
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709627
05/28/10 03:21 PM
05/28/10 03:21 PM
Southern CA
Colin Frolick Offline
Southern CA
i put that damper on my motor. i had to chase all the pulley bolt holes with a tap to make it work, i thought that was lame. the timing marks are a little faint too. "otherwise" it's fine
Re: 440 Source Dampers/Balancer...anyone use them [Re: Colin Frolick] #709628
05/28/10 08:52 PM
05/28/10 08:52 PM
Mansfield,Ohio
Mansfield,Ohio
Were the threads messed up? I think I would have sent it back if thats the case....
Anyone else have any experince with this damper.
I need one for a 6200 RPM street motor if that helps!
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709629
05/28/10 09:01 PM
05/28/10 09:01 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I would spend the extra 18 dollars on the profesinal products peice as thats what i bought looks like a quality peice i have not used it yet as im still asembling my engine
http://cgi.ebay.com/ebaymotors/Race-SFI-...sQ5fAccessories
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709630
05/28/10 09:10 PM
05/28/10 09:10 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
I have one and it now makes a great door stop.
It seized up at the half way point on the crank during install. Balancer was heated up and I used plenty of anti-seize. Turns out the ID of the balancer was undersize.
Broke a Snap-on balancer tool trying to get it off. Had to disassemble engine and put the crank on a mill and make some relief cuts with an end mill. A little heat and a new balancer tool got if off.
Of the 440Source stuff I started with in 2006...Rockers,balancer,water pump,starter,pump housing,and distributor hold down. Only the pump housing and distributor hold down are currently on my engine.
The housing is going to be replaced in the next month, so the distributor hold down is the only thing that has lasted. Great stuff!
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709631
05/28/10 09:34 PM
05/28/10 09:34 PM
Shoreline, Washington
72roadrunnergtx Offline
I'm running the painted version of that damper(I don't see it currently listed on their site), 3k+ miles on it now, so far no problems. No assembly issues with this one.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 440 Source Dampers/Balancer...anyone use them [Re: jb500] #709632
05/28/10 09:41 PM
05/28/10 09:41 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
I have one on my 505-6... Zero issues
I'm not much of a Chrome guy, so I don't really care for that Chrome finish, especially when it comes to reading those timing marks. A stick on timing tape will cure that problem easy enough however.
Re: 440 Source Dampers/Balancer...anyone use them [Re: Fastback67] #709633
05/29/10 05:01 AM
05/29/10 05:01 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Ive had one on my engine for several years. no problems.
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709634
05/29/10 07:30 AM
05/29/10 07:30 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
No experience with the 440 source balancer,but the professional products balancer only lasted one summer for me.About 200 passes and the outer ring was wiggling on the hub.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparmxz] #709635
05/29/10 10:48 AM
05/29/10 10:48 AM
Mansfield,Ohio
Mansfield,Ohio
Thnx for taking a minute to reply to this post guys.. I have a bit of info to chew on..THNX!!!!
Re: 440 Source Dampers/Balancer...anyone use them [Re: moparrulzzz] #709636
05/29/10 06:15 PM
05/29/10 06:15 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I like the Pioneer balancers.
Nautilus Racing-
