8 3/4 Pinion fine spline? #709433
05/27/10 02:32 PM
05/27/10 02:32 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
I got a new set of gears for my 8 3/4 rear. My machinist says that the new gears have a fine spline (22) and the original pinion is a coarse spline (10). He recommends that I need a new pinion. Anyone know where to get one?
Re: 8 3/4 Pinion fine spline? [Re: conv440] #709434
05/27/10 02:35 PM
05/27/10 02:35 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Chris, you can get one from your dealer or Mancini Racing. They are esy to find used as well. I assume this is for your U-code Chally ragtop? If so, you will need the 7290 large u-joint fine spline yolk.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 8 3/4 Pinion fine spline? [Re: 70440+6bbl] #709435
05/27/10 02:42 PM
05/27/10 02:42 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Roger that ...EZ to find .... 10 beans or so on eBay ...all the time.
Re: 8 3/4 Pinion fine spline? [Re: dOOc] #709436
05/27/10 02:49 PM
05/27/10 02:49 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Thanks for the quick response. Yep, it's for the Chally. I think I need the 29 spline for a 7290 u-joint like this:
http://cgi.ebay.com/ebaymotors/MOPAR-8-7...s#ht_500wt_1182
I guess I'm not gonna make it to Musclepalooza on Sunday afterall.
Re: 8 3/4 Pinion fine spline? [Re: conv440] #709437
05/27/10 03:45 PM
05/27/10 03:45 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Can anyone confirm that the OE gear has a coarse (10) spline pinion and the later ones are fine?
Re: 8 3/4 Pinion fine spline? [Re: conv440] #709438
05/27/10 03:53 PM
05/27/10 03:53 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All 742 castings, most 741 castings and some 489 casting gears were made with 10 spline yokes.
'69-'70 489 castings originally came with 10 spline pinions.
'71-'74 489 castings originally came with 29 spline pinions.
Richmond makes 10 spline 489 casting ring and pinions. Every other brand of 489 casting gears are 29 spline.
