Page 1 of 3 1 2 3
Herb McCandless oiling tips for big block/Hemi #7090
11/17/03 11:53 AM
11/17/03 11:53 AM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
This piece was written by Herb McC & is at least 10 years old-is it still good information? He was kind enough to answer oiling questions over the phone when I was rebuilding my small block stroker in the early '90s, and sent me oiling info on both small blocks and B/RB/Hemi engines. He's a pretty cool guy in my book.
OIL SYSTEMS B-RB-HEMI
McCandless Performance has many years of experience and has spent many hours on the Chrysler B-RB-Hemi motors. We have put together a list of suggested improvements for your oil system which can be made at little or no cost to you. It is very important that you follow these instructions exactly as they are described to you in the following report. Please be sure and call us if you have any questions at all on the procedures that are mentioned.
Remove all five main caps. With an 8-10” 9/32 drill bit drill the oil passages from the top of the main saddle to the lifter galley on the passenger side of the block to 9/32. Do not drill passages to the cam. Do not restrict the oil to the rockers. If you run a solid or roller lifter camshaft you should cut oil off to the lifters on the drivers side of the block. This can be done by following these instructions.
On the rear of the block, remove the pipe plug on the drivers side of the block next to the camshaft. You will need a 19/32 freeze plug. Install the 19/32 plug into the oil galley on the drivers side of the block. Drive the plug into the block about 1 1/4 inches or until you can see the passage coming across the back of the block that feeds the oil to the drivers side galley. Clean and install pipe plug. Oil is now cut off to the lifters on the drivers side of the block. The only way to cut oil off to the passenger side is by installing sleeves in each lifter.
In a street motor we highly recommend a Milodon #30930 pan and a street Hemi size pickup (1/2 inch pipe). The block must be re-drilled and tapped to 1/2” pipe. There is a standard size pickup available for this pan but why put a high volume oil pump on the motor and not increase the oil available to the pump? Once all passages are drilled, completely clean the block very thoroughly. We use a Milodon #34010 brush kit to clean all the oil passages and it works very well.
On a race motor the only system that we recommend is the Milodon dual line system. This has been the standard of the industry system on the motors for years. The dual line Milodon is very expensive but not near as costly as the price to replace a good race motor. Fix it right the first time.
We do not recommend using a stock pan that has been deepened. This type of pan runs out of oil under acceleration and deceleration. This can cause spun bearings and broken rods and also causes a costly repair bill.
Re: Herb McCandless oiling tips for big block/Hemi [Re: Stroker] #7091
11/17/03 02:03 PM
11/17/03 02:03 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Herb is a guy who is sorely missed. He spent over 45 minutes on the phone with me (I was just out of high school at the time) giving me FREE advice on proper component selection on a 440 I was building. He new I was young but never talked down to me . I always enjoyed all his clinics at the Nats. I know he still works behind the scenes for Indy and Edelbrock, but his tech talks were the best. Indy should learn some phone tips from him.
Re: Herb McCandless oiling tips for big block/Hemi [Re: SSAAHemiFan] #7092
11/17/03 07:46 PM
11/17/03 07:46 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'll second that. Herb is a Class Act. Very nice to talk to and doesn't talk down to anyone. He called me when I had a problem and answered all my dumb questions and gave me some very helpful suggestions.
Re: Herb McCandless oiling tips for big block/Hemi [Re: quickd100] #7093
11/17/03 07:53 PM
11/17/03 07:53 PM
Stroker Offline OP
Stroker  Offline OP
So should I post the small block oiling tips, or does anyone care?
Re: Herb McCandless oiling tips for big block/Hemi [Re: Stroker] #7094
11/17/03 07:59 PM
11/17/03 07:59 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Sure, on the small block stuff!
Should the passenger side on the R/B roller cam also be plugged, or is it just the drivers side?
Jeff
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: Herb McCandless oiling tips for big block/Hemi [Re: tilt] #7095
11/17/03 08:36 PM
11/17/03 08:36 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Just the drivers side. The passenger side has to have the lifter bores bushed to block the oil off. There was at one time a oil galley tube from Direct Connection that could be installed after the galley was reamed, like the ones for the small bocks. Using this tube, only #4,#6 and #8 lifter bores could be blocked, blocking #2 would restrict flow. DC stopped selling it because people were not following instructions and blocking #2 bores and losing motors.
Cecil
Re: Herb McCandless oiling tips for big block/Hemi [Re: B5 Bee] #7096
11/17/03 11:15 PM
11/17/03 11:15 PM
NC
440Jim Offline
440Jim  Offline
NC
Thanks for posting that.
It is basically what I have been doing, gathered from several others like Chuck Senatore (Muscle Motors).
Re: Herb McCandless oiling tips for big block/Hemi [Re: 440Jim] #7097
11/17/03 11:20 PM
11/17/03 11:20 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Is this a NO NO with a hyd. Roller? Or is this still an excellent mod for even a Hydraulic type roller set up?
Btw thanks also for an excellent tech tip !
JEFF
Re: Herb McCandless oiling tips for big block/Hemi [Re: tilt] #7098
11/17/03 11:27 PM
11/17/03 11:27 PM
NC
440Jim Offline
440Jim  Offline
NC
For any hydraulic lifters, do not block the driver's side oil galley. How would the lifters "hydraulic" without pressure??? The others mods should be fine.
Re: Herb McCandless oiling tips for big block/Hemi [Re: tilt] #7099
11/17/03 11:28 PM
11/17/03 11:28 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
You can't block the oil to the lifter galley and use hydraulic tappets, roller or flat.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Herb McCandless oiling tips for big block/Hemi [Re: origcharger] #7100
11/17/03 11:33 PM
11/17/03 11:33 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Thanks Guys for the advice.
I love a good thread like this one ..Very Informative !!
JEFF
Re: Herb McCandless oiling tips for big block/Hemi [Re: tilt] #7101
11/18/03 01:18 AM
11/18/03 01:18 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Another tip when drilling for 1/2" pick up. Before drilling, oval the hole with a die grinder, away from the thinnest side of the pick up boss. This will move the hole center line so after drilling and tapping, there will be almost as much meat around the tube as the 3/8" pick up had. This will also allow for a little more clearance grinding when using a stroker crank.
Cecil
Re: Herb McCandless oiling tips for big block/Hemi [Re: B5 Bee] #7102
11/18/03 11:44 AM
11/18/03 11:44 AM
Cecil
i've never tried it that way. i don't like drill bits and engine blocks very close to each other in my shop. i use a bridgeport to make the hole for the 1/2" pickup. an endmill will move the hole exactly where it needs to be. i also mill to the bottom of the poassage, radius the turn and open the other end to match the modifications that i make to the oil pump. among other things, LOL>.
Re: Herb McCandless oiling tips for big block/Hemi #7103
12/18/03 02:54 PM
12/18/03 02:54 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Is blocking off the oil to the drivers side REQUIRED when switching to a solid roller in a BB? The comp lifters have an oiling groove built into them and are not solid bodied. What oiling mods are required when going to a solid roller (with oiling grooved lifters)?
Re: Herb McCandless oiling tips for big block/Hemi [Re: Quicksilver440] #7104
12/18/03 09:05 PM
12/18/03 09:05 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
What advantage does stopping oil from going to the drivers side lifter galley??? Going through my motor now and noticed that mine is not blocked.
Re: Herb McCandless oiling tips for big block/Hemi [Re: Quicksilver440] #7105
12/18/03 11:41 PM
12/18/03 11:41 PM
no, it's not required. if you do the other oiling mods to your block and blueprint the pump, oil volume and pressure won't be a problem.
Re: Herb McCandless oiling tips for big block/Hemi #7106
12/19/03 01:25 AM
12/19/03 01:25 AM
I am a novice to engine biulding. What is the purpose of blocking off the oil to the driver side galley. My machinist was speaking of this today relating to small blocks. Does it apply there too? Also what's the purpose of the oil bypass pipe procedure in the lifter valley on a SB? Good thread.
Re: Herb McCandless oiling tips for big block/Hemi #7107
12/19/03 02:37 PM
12/19/03 02:37 PM
AndyF Offline
AndyF  Offline
blocking off the oil to the driver's side is just a way to direct the oil pressure back to the main bearings rather than have it leak away around 8 lifters that don't need it.
For high perf street motors I usually block off the driver gallery but then drill a small hole (0.090) or so in the plug so that oil still flows, but at a reduced rate. I just haven't gotten comfortable with the idea of completely blocking off the lifter gallery on a street car.
Re: Herb McCandless oiling tips for big block/Hemi #7108
12/19/03 03:05 PM
12/19/03 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is to supply oil to the front mains faster
coming from the main source from the rear(you dont have to wait for all of the other things to
get there oil before it goes to the mains in the
front)
Re: Herb McCandless oiling tips for big block/Hemi [Re: Stroker] #7109
12/19/03 03:22 PM
12/19/03 03:22 PM
In addition, blocking off the lifter galleys helps if you bend a push rod or a rocker adjuster backs off and a lifter jumps out, your oil pressure will not drop to zero.
Page 1 of 3 1 2 3
