Re: Fender tag?
[Re: b5a12bee]
#709366
05/27/10 04:13 PM
05/27/10 04:13 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Who else makes accurate fender tags besides Galen?
There is no such thing , a repop tag is EASY to spot ...
Do you have the original tag? If not you will NEVER get all the CORRECT info on a tag no matter how real it looks .
Re: Fender tag?
[Re: JohnRR]
#709367
05/27/10 04:18 PM
05/27/10 04:18 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
If you have a buildsheet, and someone who knows what they're doing, you can get an accurate tag made.
Of course, there are always exceptions and often, a tag will not show an option that was clearly ordered on the sheet. Human error I'm sure when the tags were made.
Re: Fender tag?
[Re: 2fast4yourBrain]
#709368
05/27/10 04:21 PM
05/27/10 04:21 PM
JohnRR
U.S.S.A.
all depends on where the car was built , Lynch rd car , there is info on the tag that is not on the brodcast sheet so unless you have the original you will NEVER have an accurate tag .
Also not all options are listed on the tag .
Re: Fender tag?
#709369
05/28/10 12:13 AM
05/28/10 12:13 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Every year is different, every plant is different. There are changes to what was and wasn't coded at the same plant depending on the time of year. There are changes to layouts depending on the time of year. Some plants have certain nuances to the tag that other plants didn't. It is exceedingly hard, if not impossible like John said, to make an 'accurate' tag. You can probably get close, but 'accurate' is pretty tough.
Remember... someone paid good money to have this tag made.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: Fender tag?
[Re: b5a12bee]
#709370
05/28/10 12:16 AM
05/28/10 12:16 AM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Galen doesn't make them, someone makes them for him. He just surcharges you! Also, he doesn't make the window stickers either, AAA does.
Admiration For Multiple Carburetor Vehicles...
Re: Fender tag?
[Re: Stewpar]
#709371
06/05/10 08:57 PM
06/05/10 08:57 PM
Posts: 664 Stuart, FL
Grassosgarage
Stuart, FL
Are you guys talking about the quality of the tag, or the info that's on it? I have a car with the original tag, but it's rusty, and most of the build sheet. Was hoping to get a reproduction tag. Is it worth it, or do they look really far off from the original?
'70 Cuda 440/auto '70 Duster 340/4sp project '70 Satellite convert 318 survivor
