What size bolts to secure 400 BB to engine stand? #709351
05/27/10 12:08 PM
05/27/10 12:08 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I'm going to secure a 400 bb to my engine stand. What size bolts would I need?
Thanks.
Re: What size bolts to secure 400 BB to engine stand? [Re: 74RR] #709352
05/27/10 12:25 PM
05/27/10 12:25 PM
Edgartown, MA/ Greene, ME
CharlieB Offline
CharlieB  Offline
do a search on engine stand bolts--varying opinions
Re: What size bolts to secure 400 BB to engine stand? [Re: 74RR] #709353
05/27/10 12:29 PM
05/27/10 12:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
3/8" coarse thread in whatever length your stand dictates. They vary. If you then use the bottom holes in block, you'll need those bolts extra long to put nuts on.
Re: What size bolts to secure 400 BB to engine stand? [Re: 74RR] #709354
05/27/10 12:42 PM
05/27/10 12:42 PM
IMGTX Offline
IMGTX  Offline
I use grade 8 course thread 3/8" bolts for the upper bellhousing area. The same size that is already tapped there. Make sure you use a good solid steel spacer under the bolt head and not just a couple of cheap washers. I have seen the heads get pulled into the hole the bolt's go through on some stands if there wasn't a good support under the bolt head. Most stands use holes large enough for a 7/16" bolt to go through hence the need for a space. Also Make sure the bolt threads all the way into the block and still gets tight. I cut the threads to be the just right and use a grade 8 washer between the head and spacer to prevent it from bottoming out if necessary. A loose bolt or one that doesn't extend into the block enough is a problem waiting to happen.
For the lower bolts I get extra long grade 8 bolts that will fit through the holes in the tabs at the bottom of the block and use nuts and spacers to prevent a pull through. You can usually get away with a 7/16" bolt there.
Each stand is different so you may have to get a different length or dia. for your your stand than I would need.
Just the way I do it.
