Indy EZ 295 CNC spring recommendation #709344
05/27/10 12:06 PM
05/27/10 12:06 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Anyone recommend a spring for these heads that have the same 1.55 O.D and I.D. as the springs that indy supplies with these heads?
Do not want to buy new locators, retainers, etc..
Cam is .620 with 272 duration. Drag race only on a 493. Harland 1.5 rockers.
Thanks in advance.
Re: Indy EZ 295 CNC spring recommendation [Re: Plumcrazyracing] #709345
05/27/10 12:40 PM
05/27/10 12:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You neglected to specify if it's a flat-tappet or a roller...
Re: Indy EZ 295 CNC spring recommendation [Re: BradH] #709346
05/27/10 12:43 PM
05/27/10 12:43 PM
Central Coast
P
P
Central Coast
solid roller!
Re: Indy EZ 295 CNC spring recommendation [Re: Plumcrazyracing] #709347
05/27/10 12:47 PM
05/27/10 12:47 PM
BradH Offline
BradH  Offline
Unless somebody else happens to know exactly what the dimensions of the parts that your particular heads happened to have come from Indy with, it's kind of a crap shoot.
It would be easier to get a spring recommendation based on your constraints if you could take the measurements of your current retainers, etc.
Re: Indy EZ 295 CNC spring recommendation [Re: BradH] #709348
05/27/10 02:23 PM
05/27/10 02:23 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Kmotion K950 should work fine."Todd
Re: Indy EZ 295 CNC spring recommendation [Re: sasquatch] #709349
05/27/10 06:34 PM
05/27/10 06:34 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
thats what i run in my 3 sr headed motors.mine are solid rollers also,with .650".they should drop right in,with no mods.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Indy EZ 295 CNC spring recommendation [Re: Old School] #709350
05/27/10 07:28 PM
05/27/10 07:28 PM
Central Coast
P
P
Central Coast
Thanks for the response guys. I've decided to just go with a new set of manley's and get new locators and retainers anyhow.
Can't wait to get this beast back together and get runnin. Last outing was the March Meet. Found a burnt pushrod and the next thing you know the heads are off, new rockers, pushrods, valve job, now the springs. Typical eh? It's all good though. I had the heads flowed and got some good info for the future cam upgrade!!!
