Best way to find A/C leaks. #709241
05/27/10 10:57 AM
05/27/10 10:57 AM
IMGTX Online content OP
IMGTX  Online Content OP
I have tried the die and assorted stuff but It seems like I can never find those small nagging A/C leaks.
Any good ideas?
Re: Best way to find A/C leaks. [Re: IMGTX] #709242
05/27/10 12:30 PM
05/27/10 12:30 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Wish I could help, but I sometimes find myself in the same boat. My source from whom I could borrow the sensitive sniffer (which helped about 50% of the time) moved away. My last try with the UV dye to find a slow leak met with no result (other than me longing for my youth and old teenage bedroom with the Zonk and SuperPeace posters).
I ended up taking the percentage bet, and throwing a [thankfully on hand, good used] compressor at the problem. It fixed it.
So I guess my constructive contribution here is to
Down to just a blue car now.
Re: Best way to find A/C leaks. [Re: 68HemiB] #709243
05/27/10 12:44 PM
05/27/10 12:44 PM
Houston, TX
Crunchy_Frog Offline
Houston, TX
I do believe a FLIR thermal imager would be the best, quickest, and posibly most expensive.
Re: Best way to find A/C leaks. [Re: Crunchy_Frog] #709244
05/27/10 02:19 PM
05/27/10 02:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
some ppl down here uses a soapy water to get wet all the lines and fittings to check for bubbles...
of course thats not posible on crank seal, but works fine on the rest
Re: Best way to find A/C leaks. [Re: IMGTX] #709245
05/27/10 02:53 PM
05/27/10 02:53 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
My brother-in-law made a fitting that connects to the a/c lines & allows you to fill the system w/ compressed air-usually about 40-50 psi. All you do is listen for leaks. I used the fitting on my '91 Dakota w/ r-12 & it helped me find the leak in the coils buried in the dash. Like you, the dye didn't help me find the leaks that are buried.
Re: Best way to find A/C leaks. [Re: fal3] #709246
05/27/10 02:59 PM
05/27/10 02:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Know the system and the problem areas.
Most leaks are at the fitting seals, the compressor shaft seal or other places where 2 parts come together. There are also evaporator leaks and condenser leaks (more common), hose leaks and ceacked lines (less common).
The leak checkers are better than the dyes, but different leaks require different tools. Have and use all of them.
Re: Best way to find A/C leaks. [Re: Crunchy_Frog] #709247
05/27/10 04:35 PM
05/27/10 04:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Does Auto Zone rent that "FLIR thermal imager"? Sounds like everyone should have one in there glove compartment.
The last 2 leaks I repaired here lately were both evaporators. One on a 2000 F-450 and a 98 chevy truck.
If I can't find anything outside than 95% chance it's the evaparator.
Picture of my Florencent light and dye injector,for anyone interested.
Was gonna tell you it was a thermal imagery thingy.
Re: Best way to find A/C leaks. [Re: Challenger 1] #709248
05/27/10 07:00 PM
05/27/10 07:00 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I know this is a bit OT but it's A/C related. When my dad passed, he left me his tools and and such. Among them was a A/C recovery vacuum and A/C gauges etc. I went to use the pump and found that it didn't work. Went to my local auto parts store to see if they had one I could rent. The guy I usually deal with spoke softly and said, "I didn't tell you this, but hook up your gauges and the one you would hook up to the pump just hook it to an engine vacuum and let the car run until the gauges run negative vacuum. Add freon and your good to go." Well I don't know how common this knowledge is and I know how illegal it could be and I'm not saying I actually did it so DAMHIK it works but it "probably" does! Now remember, "I did NOT tell you this" The system didn't have any freon to leak into the atmophere anyway because it already had Warm air was blowing on "Max A/C" hence the need to vacuum in the first place
Re: Best way to find A/C leaks. [Re: Challenger 1] #709249
05/27/10 07:18 PM
05/27/10 07:18 PM
Houston, TX
Houston, TX
I sure wish they did, or even sun belt. I was surprised with how useful they are when i started using one.
Re: Best way to find A/C leaks. [Re: Crunchy_Frog] #709250
05/27/10 07:52 PM
05/27/10 07:52 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Scott Carl, since you didn't do it , I will add this for those that might try; burning refrigerant creates phosgene. VERY nasty stuff!!!!
http://wiki.answers.com/Q/Phosgene_gas_exposure_from_working_with_freon.
Re: Best way to find A/C leaks. [Re: IMGTX] #709251
05/27/10 07:53 PM
05/27/10 07:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some A/C shops recommend leak testing with nitrogen when all else fails.
Re: Best way to find A/C leaks. [Re: RodStRace] #709252
05/27/10 08:03 PM
05/27/10 08:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
A long time ago(1985) I broke loose some AC fittings on a 76 dart in my gargae during the winter. I had one of those round wick type kerosene heaters sitting on the floor in my 2 car garage which was on, I looked out from under the hood to see a thick black smoke coluum pouring out of the top of the heater the same diameter as the heater. It filled my garage from the ceiling half way down to the floor in a minutes time. Luckly I noticed it before it was too late and got my garage door open and I ran out of there. I felt sick for a while after that.
That was the last time I ever sat anything on the floor of my garage with a open flame, wall heaters for me from then on. It was bad gas fast when the freon got to the open flame. FWIW
Re: Best way to find A/C leaks. [Re: RodStRace] #709253
05/27/10 08:05 PM
05/27/10 08:05 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I knew there had to be a down side, but thanks That sound worse that welding on galvanized steel
Re: Best way to find A/C leaks. [Re: Scott Carl] #709254
05/27/10 09:33 PM
05/27/10 09:33 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
if youre not using those yellow tinted glasses when looking for leaks using the uv dye I would suggest picking up a pair of those. They make spotting the leak 100x easier
