PAINTING CAR QUESTION
#708892
05/26/10 09:57 PM
05/26/10 09:57 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
okay, i am ready for the paint, i have done all the work myself in my garage and now going to tackle the paint, here is my question, from the spot painting and primer painting i have done, i do not know if i can hold out to do the whole car at one time, i know that i will have a tape mark if i do not paint the car at the seams, can i paint the whole front cap and under hood cover up the rest of the car let dry then cover up the front cap and finish painting the door jambs and rear of the car? and do the same on the clear, i plan on painting the car all the same day with a gallon of paint i have, will the front and rear still match? will you be able to tell the difference?
Re: PAINTING CAR QUESTION
[Re: cornet684me]
#708893
05/26/10 10:06 PM
05/26/10 10:06 PM
DaytonaTurbo
Manitoba, Canada
Regular color or a metallic?
For mine I don't have enough room in my garage to do everything at once, so I'll be doing the door jams, engine bay and trunk seperately, then taping them off and doing the outside of the car. If I tape it off at the places where the body panels meet, ie where the fenders meet the inner fenders, where the rear 1/4 panels wrap around and meet the door jams, etc, I don't think the tape lines would even be visible.
[Re: Neil]
#708896
05/26/10 10:24 PM
05/26/10 10:24 PM
cornet684me
Brandon, Ms
my main concern is , if i paint a smaller area at a time, i will do a much better job, than running all over the car at one time, i just went out with my paint gun and it is going to be pretty tricky for me and did a test practice with my paint gun to get around my b-body without touching it in my garage, and the car is so big, i am trying to get smaller areas for me to paint at one time, however, i have almost 3years in the project and do not want the paint to look bad, i do plan on color sanding and buffing and polishing the whole car when i finish painting
