CCE 3 way front shocks where should I set them #708776
05/26/10 09:31 PM
05/26/10 09:31 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I just aquired a set of front 3 way adjustable front shocks. What setting should I put them on? They are going on a 1972 Dodge Dart with a 360 and a 727 footbraking with regular leafs on the back and 8.5x26-14 slicks on the rear. strictly strip
Re: CCE 3 way front shocks where should I set them [Re: flatiron] #708777
05/26/10 09:36 PM
05/26/10 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most likely the softest possible... unless you have
a wheel stand issue
Re: CCE 3 way front shocks where should I set them [Re: MR_P_BODY] #708778
05/26/10 09:47 PM
05/26/10 09:47 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
So is that the 90/10 setting? Am I understanding it right that your front end comes up easier transfering weight to the back.
Re: CCE 3 way front shocks where should I set them [Re: flatiron] #708779
05/26/10 09:50 PM
05/26/10 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Correct... if all goes right it should
