Re: motorhome 360 torque converter ?s
[Re: Kern Dog]
#708479
05/26/10 06:01 PM
05/26/10 06:01 PM
Posts: 15,487 Florida
scratchnfotraction
yes you can run any n balance TC with the B&M weighted flex plate...but you can not run the stock 360 weighted TC and the weighted flexplate together a local tranz shop should be able to get a reman one with the weight for less than 200$ if its staying in the 1 ton chassis then a stock low stall TC would be the best,IMO if your swaping it to a car then a High stall would get my vote
[Re: John_Kunkel]
#708484
05/26/10 08:57 PM
05/26/10 08:57 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
I have read here that the B&M 360 flexplate was discontinued.
Only the 904 version of the flexplate was discontinued, the 727 version is still available.
bummer. So i need to order one of these before they're gone? may have to order a couple. http://www.summitracing.com/parts/BMM-10239/
[Re: 70AARcuda]
#708486
05/27/10 03:43 PM
05/27/10 03:43 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Although the bolt circle is the same, the larger diameter of the 727 flexplate might not be compatible with the smaller 122 tooth ring gear on the 904. I think that's why B&M made a separate 904 flexplate.
