Re: Gains from intake swap?
[Re: kzinge1]
#707600
05/25/10 07:39 PM
05/25/10 07:39 PM
fullmetaljacket
The Victor really awakes in the mid range and up. Though it is responsive even in the low end on a middle weight car. Depending on your duration, Head work, gearing etc the Vic may pick you up a little or better. I would await for some intake gurus on this board that will set you in the right direction. My Vic works swell with my stage 2 ported heads and stock port windows.
