mini tub A body with spring relocate. What size tire? #706949
05/25/10 12:04 AM
05/25/10 12:04 AM
Carstairs, Alberta, Canada
dave571 Offline OP
dave571  Offline OP
As described, 67 dart with mini tub and spring relocate.
How big a tire are you running?
Looking to run a 325 50 15 my et street radial on a 10" wheel.
Re: mini tub A body with spring relocate. What size tire? [Re: dave571] #706950
05/25/10 12:09 AM
05/25/10 12:09 AM
Renton Washington
Triple Threat Offline
Renton Washington
Frame rail to Quarter you'll have roughly 14-14.5" to work with. 325's will fit.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: mini tub A body with spring relocate. What size tire? [Re: dave571] #706951
05/25/10 12:11 AM
05/25/10 12:11 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I use to fit a true 10/28 and still had a little over an inch on each side for clearance, on my 69 Valiant
Re: mini tub A body with spring relocate. What size tire? [Re: dave571] #706952
05/25/10 03:19 AM
05/25/10 03:19 AM
Netherlands
72Challenger Offline
Netherlands
Don't know about these darts but on my Duster I did a minitub w/ springs relocated under the chassis and I can get away with 335/35/17's on 11x17" rims. Looks badass for a panther pink streetcar w/ lowering blocks.
Re: mini tub A body with spring relocate. What size tire? [Re: 72Challenger] #706953
05/25/10 03:35 AM
05/25/10 03:35 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I just put these 315/60/15's HOOSIER DOT Drag Radials on My 67 Valiant and I could easily go another inch wider. 10" rim, 11.1 tread, 29.7 tall. My wheel openings are stretched to accept the taller tire.
SRT DEMON ONE SEAT
Re: mini tub A body with spring relocate. What size tire? [Re: dave571] #706954
05/25/10 12:15 PM
05/25/10 12:15 PM
Are you willing to trim or stretch the wheel opening? If so a 315x60x15 or a 295x65x15 on a ten inch wheel will fit My duster has had the wheel openings stretched five inches, three on the front side and two on the rear, I moved the rear end forward one inch My intent was to be able to run that size and not get anyones attention(on the street) of having a big tire
Re: mini tub A body with spring relocate. What size tire? [Re: Cab_Burge] #706955
05/25/10 01:39 PM
05/25/10 01:39 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I have 28x11.5 (10” tread, 11.2” section) QTP’s on a 10” rim…they fit fine, could go a little wider if I wanted to.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: mini tub A body with spring relocate. What size ti [Re: FlyFish] #706956
05/25/10 09:31 PM
05/25/10 09:31 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
30x13.50 et streets on the 68...
Re: mini tub A body with spring relocate. What size ti [Re: BEEQUIK] #706957
05/25/10 09:35 PM
05/25/10 09:35 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
another...
Re: mini tub A body with spring relocate. What size ti [Re: BEEQUIK] #706958
05/25/10 10:38 PM
05/25/10 10:38 PM
mo
ALKYW5DART Offline
ALKYW5DART  Offline
mo
i got 28 10.5 in my 71 dart with alot of room around the tire will go bigger when these wear out
Re: mini tub A body with spring relocate. What size ti [Re: ALKYW5DART] #706959
05/25/10 11:02 PM
05/25/10 11:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i had my springs moved in about 4 yrs ago to the opp.side of the frame not into th frame( i think the kit came from abc something like that) 70 duster i had 10" pro star wheels with 29/10w m/t slicks looked good just not enough motor for that tire hahahah..little 340the kit worked out good anybody with some simple tools and welder can fab. about the same way it worked...
Re: mini tub A body with spring relocate. What size ti [Re: earthmover] #706960
06/08/10 02:38 PM
06/08/10 02:38 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Re: mini tub A body with spring relocate. What size ti [Re: Sixpak] #706961
06/08/10 03:08 PM
06/08/10 03:08 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
M/T 29.5 x 11.5 on a 10" wheels fit really nice....
Re: mini tub A body with spring relocate. What size tire? [Re: Cab_Burge] #706962
06/08/10 03:21 PM
06/08/10 03:21 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Yea. I can hardly notice.
Re: mini tub A body with spring relocate. What size tire? [Re: RacerGofKGB] #706963
06/08/10 05:26 PM
06/08/10 05:26 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
I did the same thing to my 67 Dart, and plan on using a 325/50R15 tire on a 10 inch wheel.
The tubs and springs have been moved, but when I measured for the wheels, I needed to run 7 1/2" of backspace. This was not the look I was going for. Besides, the rear disc set up that I have recommends no more than 3 1/2" of backspace.
This means I will be having my rear end narrowed by 4" on each side to obtain the proper backspacing.
1970 Duster 340 clone
Re: mini tub A body with spring relocate. What size tire? [Re: BrianT] #706964
06/08/10 06:41 PM
06/08/10 06:41 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
What back spacing are you guys running with 10 in wheel?
EDDIE B
Re: mini tub A body with spring relocate. What size tire? [Re: dave571] #706965
06/08/10 08:34 PM
06/08/10 08:34 PM
MI
RickRoss Offline
RickRoss  Offline
MI
M/T 3057 28x11.5 x15
Re: mini tub A body with spring relocate. What size tire? [Re: EDDIEB] #706966
06/08/10 08:40 PM
06/08/10 08:40 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
I plan on running 3 1/2 inches...as soon as the rear end is narrowed.
Re: mini tub A body with spring relocate. What size tire? [Re: BrianT] #706967
06/08/10 11:39 PM
06/08/10 11:39 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Early A body.
mini tubbed and leafs moved in 3 " a side.
Housing shortened 2 1/2 " a side and moved back 1 ".
I am hoping a 325 - 50 / 15 will fit , but it is gonna be tight.
15 X 10 with 6.5 " back space and it may need a 1/4 to 3/8 " spacer.
Re: mini tub A body with spring relocate. What size tire? [Re: tubtar] #706968
06/09/10 07:36 AM
06/09/10 07:36 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
315/60/15 ET Street Radials. the spring boxes are on the "inside" part of the frame rails... 71 dart - 15*10 ... 3-3/8 back space convo pros. I cant remember what I had the housing cut to though... has discs on back also.
Mopar Performance
