synthetic gear oil need modifier? #706943
05/24/10 11:59 PM
05/24/10 11:59 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Do I need to add the limited slip modifier to the rear diff if I use synthetic gear lube?
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: synthetic gear oil need modifier? [Re: EV2CUDA] #706944
05/25/10 12:04 AM
05/25/10 12:04 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Only if the diff has clutches in it.
Re: synthetic gear oil need modifier? [Re: EV2CUDA] #706945
05/25/10 12:08 AM
05/25/10 12:08 AM
Az
Crizila Offline
Crizila  Offline
Az
Try it without it first. If it doesn't chatter, you don't need it.
Fastest 300
Re: synthetic gear oil need modifier? [Re: Crizila] #706946
05/25/10 07:48 AM
05/25/10 07:48 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Yep. Amsoil in the Dana 60. No need for the additive.
Re: synthetic gear oil need modifier? [Re: EV2CUDA] #706947
05/25/10 10:42 PM
05/25/10 10:42 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Royal Purple does not need the additive
Re: synthetic gear oil need modifier? [Re: torkrules] #706948
05/26/10 01:17 AM
05/26/10 01:17 AM
IN
ahy Offline
ahy  Offline
IN
I had a Jeep with limited slip diffs. On a road trip, I had the dealer change the oil due to contamination with the recommended synthetic lube They forgot to add the modifier. A couple of hundred miles into the trip home it started chattering and grabbing terribly on any kind of turn. I stopped and got some modifier at an auto parts store, put it in and a few miles later all was well again.
Based on that I would say yes, add the modifier.
