B&M pro ratchet or magnum grip pro stick #706707
05/24/10 05:37 PM
05/24/10 05:37 PM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
want to add one of these two shifters to the order. it won't be any other make or model just either one of these. anyone have experience with them? thanks
Re: B&M pro ratchet or magnum grip pro stick [Re: jamesc] #706708
05/24/10 05:48 PM
05/24/10 05:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the pro ratchet... love it... 2 fingers to flip
it to the next gear... if I remember right the other
has a pistol grip which might be nice but you dont need
your whole hand to shift it.... JMO
Re: B&M pro ratchet or magnum grip pro stick [Re: MR_P_BODY] #706709
05/24/10 05:55 PM
05/24/10 05:55 PM
Buford, GA
I_bleed_MOPAR Online content
I_bleed_MOPAR  Online Content
Buford, GA
Have one in the Charger and had one in my '67 R/T. Never had a minutes trouble from either.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: B&M pro ratchet or magnum grip pro stick [Re: MR_P_BODY] #706710
05/24/10 05:56 PM
05/24/10 05:56 PM
jamesc Offline OP
jamesc  Offline OP
yea think i'm gonna get the pro ratchet, plus it's cheaper and i believe simpler to use...ok it's in the cart. i gotta hammer all this stuff out ASAP i want to get going on this mess. i'm fretting over the fuel system right now. heck for this engine the HV mechanical would do the trick but i'm going to get a low end electric. thinking about the edelbrock billet pump
Re: B&M pro ratchet or magnum grip pro stick [Re: I_bleed_MOPAR] #706711
05/24/10 05:59 PM
05/24/10 05:59 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Pro ratchet here also. Witha rev man valve body, its very easy to add a air shifter if you want to.
