Best non factory Mopar wiring kits. (aftermarket.) #70653
06/09/08 10:19 PM
06/09/08 10:19 PM
In a town not near you.
clownzilla Offline OP
I was looking through aftermarket wiring kits for a street machine application.
Painless seemed very vague.
Ez wiring even more vague.
Ron Francis wiring seemed the most expensive, but their website seemed to have alot more to offer for mopar applications, and they detailed everything in the kit.
But the price was alot more as well.
I was very impressed with their website and by the looks of painless and ez wiring, I can see why Ron Francis would kill the competition in sales even if they are more pricey.
Does anyone here have experience with the ron francis mopar styled wiring, if so, what are you using it in and how did it work for you.
Any other suggestions welcome, these were the only guys I could think of since most of the stuff going in my 67 cuda is aftermarket except for a few things so Ron Francis wiring may be a little over the top and I may be better off with a cheaper kit.
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: clownzilla] #70654
06/10/08 01:51 AM
06/10/08 01:51 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
given any thought to making your own? pick up 8 or 10 rolls of differently colored wire, a bunch of connectors and draw it up. It aint rocket surgery
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: nomore65BelvJim] #70655
06/10/08 08:59 AM
06/10/08 08:59 AM
I could do that, but I did not want a bunch of ugly crimp connectors and stuff everywhere, but maybe that's unavoidable with the kits as well....dunno, that's why I asked.
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: clownzilla] #70656
06/10/08 10:06 AM
06/10/08 10:06 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
The built from scratch is a more expensive way, if you want enough colors and wire gauges to be similar to an OEM installation. Bulk wire is expensive these days. I have never seen a Ron Francis kit, but I heard good things and bad things. I'd suggest getting a kit with a good fuse block with machine crimped connectors on it. The cheap kits sometimes use a bunch of aux fuse blocks stuck together as the main fuse block, and the crimping could be suspect.
As for the other end of the wires, most kits provide you with cheap insulated terminals that I would avoid. So factor in kit + good terminals + good shrink tubing (dual wall adhesive lined) + a few extras like junction points + harness wrap, or convoluted tubing or a bunch of tie wraps, grommets + some good tools.
I have no idea what Ron Francis supplies, try to get as much info as possible to be able to compare apples to apples.
Good luck,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: kick_the_reverb] #70657
06/10/08 10:48 AM
06/10/08 10:48 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Kwik wire is the best bang for the buck hands down
Ken
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: kick_the_reverb] #70658
06/10/08 10:50 AM
06/10/08 10:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Painless wiring harnesses are marked as to where the wires go.
Re: Best non factory Mopar wiring kits. (aftermarket.) [Re: clownzilla] #70659
06/10/08 11:17 AM
06/10/08 11:17 AM
usa,new jersey
69belvi Offline
69belvi  Offline
usa,new jersey
i just got the engine side only w/ecu, from year one,which is made by m&h.it was perfect.also picked up a NEW firewall bulk connector with engine side plugs from mopars by crane.
