8 3/4 axle bearing/spool question #706365
05/24/10 09:51 AM
05/24/10 09:51 AM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
stupid question here but i'm figuring in order to use a spool you have to use the green axle bearings as the tapered bearings need something in the center to bear against in order to maintain clearances. i have a completely rebuilt rear axle but it has a 3.91 with cone suregrip (all that was available new at the time) with moser axles and stock tapered bearings. i hate to redo the whole rear axle but if i'm going to do something with this dart i want to run a 4.30 gear and spool. has anyone ever done this (used tapered bearings) and made a spacer to go in the spool for the axles to bear against?
Re: 8 3/4 axle bearing/spool question [Re: jamesc] #706366
05/24/10 11:01 AM
05/24/10 11:01 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can machine a 1.5" spacer, or simply install a thrust block from an open differential.
BTW I stock all the parts you need including the spacer. E-mail me if you are interested.
Re: 8 3/4 axle bearing/spool question [Re: DoctorDiff] #706367
05/24/10 01:54 PM
05/24/10 01:54 PM
jamesc Offline OP
jamesc  Offline OP
great thanks Cass, i may be calling you in the near future. at this point i'm leaning real hard towards doing something with this car. if i finalize that decision i'm going to be needing an offset hanger kit as well. knowing i can use these existing axles and bearings is nice. i can just turn a spacer on the lathe.
