Re: BCR girdle. What windage tray?
[Re: moparlulu]
#706223
05/25/10 02:56 AM
05/25/10 02:56 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
440 source tray, Milodon low profile pan, and modified Milodon deep pan pickup. The windage tray is wah deeper than it needs to be, and i did have to make clearance holes for the girdle to main studs, and around the internal pickup tube. The longer, deep pan, pickup tube was heated and gently bent to clear the girdle and girdle stud, then heated and bent to get the correct depth to the bottom of the oil pan.
