4 Link settings a little long
#705619
05/23/10 11:41 AM
05/23/10 11:41 AM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Hey guys, Time to pick some brains, as you know we only have few runs on car with 4 link and need some advice car weighs 2947 with me, 50.3% on rear 116 inch wheelbase cg is 20 inches, right now 4 link is set 58.8 out 9.4 up and 93% antisquat. 60' are not great 1.26- 1.30. What would you set 4 link to out height antisquat 40.1 5.85 83.2 40.5 7.7 110.2 41.1 8.5 119.9 41.1 7.5 105.7 41.2 9.5 133.3 41.7 10.3 143.9 41.7 9.3 129.8 42.2 11.2 154.7 42.3 3.8 51.9 43.4 4.5 60.5 44.3 5.4 70.7 44.3 5.4 70.5 44.8 6.3 82.1 45.5 7.3 93.3 45.7 8.3 105.5 45.8 7.2 91.5 46.2 9.4 117.6 46.3 10.4 129.9 46.7 11.5 142.7 46.7 9.2 114.8 48.3 2.7 32.6 49 5 58.9 49.5 3.7 43.5 50 7.1 82.7 50.2 4.6 53 50.7 9.4 107.2 51.2 5.8 65.2 51.3 11.7 132.5 51.5 6.7 75.8 52.3 8 88.9 52.5 9 99.5 53.1 10.4 113.5 55.5 2.9 30.6 56.7 4.3 44.1 56.9 5.3 53.7 57.9 6.8 68.1 58.1 7.8 77.7 58.2 0.9 9.5 58.8 9.4 92.8 Dave Morgan recommends 46.7. The car makes 900+hp and 850 fttq with 14 32 MT tire. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: 4 Link settings a little long
[Re: Quicktree]
#705621
05/23/10 01:00 PM
05/23/10 01:00 PM
Mopar_racer_99
Woodstock , Georgia
We are having problems with hooking up. sometimes it hooks and others it blows tires off the car. But car is going straight as an arrow.John
[Re: Mopar_racer_99]
#705622
05/23/10 01:08 PM
05/23/10 01:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would pull it back some... like the 46.7 9.2 EDIT if it didnt work good there then I would start going out to 48, 49, 50
[Re: Quicktree]
#705624
05/23/10 02:57 PM
05/23/10 02:57 PM
Mopar_racer_99
Woodstock , Georgia
Strange strut front end with 3.5 inch travel 350#, the back is strange single adjustable with a 150 # spring, anti roll bar is set neutral. 1 degree pinion angle. John
#705625
05/23/10 03:10 PM
05/23/10 03:10 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I would pull it back some as well. But that is just me. Also think you have a bit to much spring back there for the weight.
[Re: MR_P_BODY]
#705628
05/23/10 06:01 PM
05/23/10 06:01 PM
Mopar_racer_99
Woodstock , Georgia
I rechecked rear spring is a 130, sorry for confusion. I think down at sgmp we will set the 4 link to 46 and 9 setting Mr P said. John
[Re: Chassisman]
#705630
05/24/10 03:38 AM
05/24/10 03:38 AM
Mopar_racer_99
Woodstock , Georgia
Thank You Chassisman I never knew that,we will check that out at SGMP on Friday, when I reset the 4 Link. John
#705631
05/24/10 10:30 AM
05/24/10 10:30 AM
Al_Alguire
Las Vegas
I would think 110 would also be a better choice. IMO the 150 is WAY to much spring.
