Suggestions for engine swapping problem.
#705479
05/22/10 11:58 PM
05/22/10 11:58 PM
Posts: 4,518 Indiana
MonGoo$e
Indiana
Okay, I'm at my wits end. Had to just call it a night. 73 Duster, old 318 car, I'm swapped a 360 made into a Stroker. P/S, 904. Spool mount set up. Swapping in Motor, and Transmission together.
Me and some buddies worked the engine down into the car..the passenger header was giving me a lot of issues laying loose in the engine bay, so I just pulled it out, and dropped it in..both spool motor mounts seated, and their washers where they should be. the transmission mount likewise, get it into place and it bolts right in. I leave the motor mounts in front loose, so I can bump motor up and slip header in that way on the pass side.
I jack car up. and use engine hoist to raise engine. No problem, I slip header in from underneath. had to take oil filter off but it made the area it needed to be in. well for it to bolt up, engine needs to drop back down.
i take car off jack while buddy aids the engine hoist so they are evenly let down. i get car down, he gets hoist where it is about to set engine in the k frame.
Then it happened, the drivers side spool slipped right in, and the passenger side...didn't. its bolt rests just above the k frame mount. You can push and push..no recoil, it's jammed there, and funny thing it, the mount and spool looks like they should just fall together. Both headers are loose..you can rattle them around, the steering clears everything. the oil pan clears everything. the starter, clears everything. in fact I am frustrated it was just in place and a simple lift to one side won't let it seat.
Going to have another look tomorrow..any suggestions in the meantime? thanks..
Re: Suggestions for engine swapping problem.
[Re: MonGoo$e]
#705481
05/23/10 02:14 AM
05/23/10 02:14 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The through bolts must be pushed out in order to drop into the ears. The washer is captured and needs to clear the lip.
Or
Try to loosen the mounts from the engine. Then see if it will drop in.
[Re: MonGoo$e]
#705485
05/23/10 12:54 PM
05/23/10 12:54 PM
Posts: 15,487 Florida
scratchnfotraction
may have to bend the craddle ears a little to let the spool go down into the craddle make sure the washers are not hanging up on the ears raise the tail shaft of the tranz with a jack some to have the engine level going down and not tilted up in the front are you sure the spools are mounted on the block ears in the correct position (front or back of lugs on the block) I like to have the cross member out and a jack under the tail shaft while the engine hangs from the hoist much ez-er to move around,the bolts like to drop down ito the craddle when the are horozontal going straight down relax and take you time,they are the ez ones to do IMO
