9/16" and 11/16" tie rods interchangable? #705365
05/22/10 09:27 PM
05/22/10 09:27 PM
Erda, UT
67Charger Offline OP
Erda, UT
As long as I do both ends and the sleeve, I can swap up to the bigger setup, right? No problems with the fit of the tapered studs?
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 9/16" and 11/16" tie rods interchangable? [Re: 67Charger] #705366
05/22/10 10:06 PM
05/22/10 10:06 PM
IN
ahy Offline
ahy  Offline
IN
Correct. There should be no difference in the taper bolt. I made that modification on a '70 E with no problem.
Re: 9/16" and 11/16" tie rods interchangable? [Re: 67Charger] #705367
05/22/10 11:39 PM
05/22/10 11:39 PM
AndyF Offline
AndyF  Offline
Bolts right in. Often times the larger setup is less expensive than stock replacements. I guess the larger tie rod ends are higher volume units or something.
Re: 9/16" and 11/16" tie rods interchangable? [Re: 67Charger] #705368
05/22/10 11:39 PM
05/22/10 11:39 PM
MAY have to shorten the sleeves to match the ones you're replacing (just eyeball them) and actually the more thread engagement you get the better as long as it'll let you adj for the slight toe in and other than that as said it bolts/fits perfect.
Re: 9/16" and 11/16" tie rods interchangable? [Re: RapidRobert] #705369
05/22/10 11:55 PM
05/22/10 11:55 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Is there noticeably less deflection when making the swap?
I want my fair share
Re: 9/16" and 11/16" tie rods interchangable? [Re: SomeCarGuy] #705370
05/23/10 12:09 AM
05/23/10 12:09 AM
Erda, UT
Erda, UT
What year should I be looking for?
Re: 9/16" and 11/16" tie rods interchangable? [Re: 67Charger] #705371
05/23/10 08:12 PM
05/23/10 08:12 PM
Andrewh Offline
Andrewh  Offline
74 newport.
