9/16" and 11/16" tie rods interchangable?
#705365
05/22/10 09:27 PM
05/22/10 09:27 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
As long as I do both ends and the sleeve, I can swap up to the bigger setup, right? No problems with the fit of the tapered studs?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 9/16" and 11/16" tie rods interchangable?
[Re: 67Charger]
#705368
05/22/10 11:39 PM
05/22/10 11:39 PM
RapidRobert
MAY have to shorten the sleeves to match the ones you're replacing (just eyeball them) and actually the more thread engagement you get the better as long as it'll let you adj for the slight toe in and other than that as said it bolts/fits perfect.
[Re: SomeCarGuy]
#705370
05/23/10 12:09 AM
05/23/10 12:09 AM
67Charger
Erda, UT
What year should I be looking for?
[Re: 67Charger]
#705371
05/23/10 08:12 PM
05/23/10 08:12 PM
Andrewh
