Re: 10.5 to 1 pistons
[Re: DAMOPARS]
#705069
05/22/10 03:56 PM
05/22/10 03:56 PM
Posts: 7,506 Az
Crizila
Az
Numbers are based on stock or Mfg. deck height - which is almost never "0" and on some SB's as much as .060" down the hole.
Fastest 300
[Re: Crizila]
#705071
05/22/10 03:58 PM
05/22/10 03:58 PM
Challenger 1
Cincinnati, Ohio
SB 10 1/2 pistons are sticking out .025-030 or so.
[Re: Challenger 1]
#705072
05/22/10 04:48 PM
05/22/10 04:48 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I have 10.5 compression and my pistons are down .017...on a 360 with .024 head gaskets and 63 cc heads...
you need to know bore how much the piston is down or out of the bore...CC of the head...CC of the head gasket..
alot of 10.5 pistons end up as 9.5 even if they are out of the bore...unless the heads are CC ...
the question is what are you trying to do...or what pistons are you looking at???
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#705073
05/22/10 06:48 PM
05/22/10 06:48 PM
Posts: 4,978 VA
DAMOPARS
VA
[Re: DAMOPARS]
#705074
05/22/10 06:51 PM
05/22/10 06:51 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
If you get 10.5 to 1 pistons. How do they figure this out? Stock deck height or zero deck? Thanks
If you are looking at different manufacturers sites or catalogs you will need to search around and figure out what assumptions they are making to calculate a specific compression ratio. For example, if you go to the KB site, they will tell you what compression ratio you will get depending on the combustion chamber volume of your heads.
However,what you also need to know is that they are assuming you are using 0.030 overbore pistons and that the deck clearance (including gasket) is 0.040". So in the case of KB, if you are using a 0.040" thickness head gasket, then yes you would need zero deck clearance to get the same compressin ratio as they claim for some specific combustion chamber size. Clear as mud right?
From what I have seen, there is not a standard for advertised compression ratios, so you'd have to check with the specific manufacturer to figure out what deck height and gasket thickness they are basing their numbers on.
[Re: rss]
#705077
05/22/10 09:37 PM
05/22/10 09:37 PM
DaytonaTurbo
Manitoba, Canada
That's why the piston manufacturers publish piston compression height. This way you can do the calculations yourself: block deck height - (piston compression height + rod length + (stroke/2)) will give you how far in the hole your pistons are. However you are still making assumptions about machining variances in the rods/crank/pistons as well as you are assuming to KNOW what your block deck height is. Can't accurately just take the factory published # because the factory blocks do vary in deck height.
383man
[Re: DaytonaTurbo]
#705078
05/22/10 11:57 PM
05/22/10 11:57 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Piston manufactors give advertised comp ratio on the assumption of all stock specs. And of course on the BB Mopar the year and head will need to be known. I always figure I will have to do final machine work to get the comp I want with any piston. I always like to cc my heads and know my deck height before I get pistons but no matter how you figure it you always have to assemble the pistons in the shortblock and take final measurements to get the exact comp you are after. Ron
[Re: DAMOPARS]
#705081
05/23/10 08:16 AM
05/23/10 08:16 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I'll ask the STUPID question ... WHAT ENGINE are you talking about ?
There are a lot of ASSumptions in this thread without knowing the engine size.
[Re: JohnRR]
#705082
05/23/10 04:25 PM
05/23/10 04:25 PM
Posts: 4,978 VA
DAMOPARS
VA
Why does it matter what engine it is? 10.5 pistons are sold for SB and BB right? If you want to go with mine it is a 400 - 440 crank 4.375 bore .035 over 3.750 stroke 6.768 rods 1.320 CH -6cc pistons 80 cc heads I was just curious
