10.5 to 1 pistons #705068
05/22/10 03:47 PM
05/22/10 03:47 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
If you get 10.5 to 1 pistons.
How do they figure this out?
Stock deck height or zero deck?
Re: 10.5 to 1 pistons [Re: DAMOPARS] #705069
05/22/10 03:56 PM
05/22/10 03:56 PM
Az
Crizila Offline
Crizila  Offline
Az
Numbers are based on stock or Mfg. deck height - which is almost never "0" and on some SB's as much as .060" down the hole.
Fastest 300
Re: 10.5 to 1 pistons [Re: DAMOPARS] #705070
05/22/10 03:58 PM
05/22/10 03:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A piston is a piston until you know what it's surroundings are going to be. Cylinder deck height and the piston height relative to the top of the deck at the top of the stroke, combustion chamber volume, and head gasket thickness all determine what the mechanical compression ratio is.
Re: 10.5 to 1 pistons [Re: Crizila] #705071
05/22/10 03:58 PM
05/22/10 03:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
SB 10 1/2 pistons are sticking out .025-030 or so.
Re: 10.5 to 1 pistons [Re: Challenger 1] #705072
05/22/10 04:48 PM
05/22/10 04:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I have 10.5 compression and my pistons are down .017...on a 360 with .024 head gaskets and 63 cc heads...
you need to know bore how much the piston is down or out of the bore...CC of the head...CC of the head gasket..
alot of 10.5 pistons end up as 9.5 even if they are out of the bore...unless the heads are CC ...
the question is what are you trying to do...or what pistons are you looking at???
Tony
70 AARCuda Vitamin C
Re: 10.5 to 1 pistons [Re: 70AARcuda] #705073
05/22/10 06:48 PM
05/22/10 06:48 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Thanks All
Re: 10.5 to 1 pistons [Re: DAMOPARS] #705074
05/22/10 06:51 PM
05/22/10 06:51 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
If you are looking at different manufacturers sites or catalogs you will need to search around and figure out what assumptions they are making to calculate a specific compression ratio. For example, if you go to the KB site, they will tell you what compression ratio you will get depending on the combustion chamber volume of your heads.
However,what you also need to know is that they are assuming you are using 0.030 overbore pistons and that the deck clearance (including gasket) is 0.040". So in the case of KB, if you are using a 0.040" thickness head gasket, then yes you would need zero deck clearance to get the same compressin ratio as they claim for some specific combustion chamber size. Clear as mud right?
From what I have seen, there is not a standard for advertised compression ratios, so you'd have to check with the specific manufacturer to figure out what deck height and gasket thickness they are basing their numbers on.
Re: 10.5 to 1 pistons [Re: rss] #705075
05/22/10 07:22 PM
05/22/10 07:22 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Typically the stock Chrysler pistons and aftermarket pistons of the 70's era came out at .75-1 point under advertised. 10-1 advertised were typically 9-1 or 9.25-1 with the original machining of deck heights and chamber volumes.
Sheldon
Re: 10.5 to 1 pistons [Re: RUNCHARGER] #705076
05/22/10 09:32 PM
05/22/10 09:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
20 thou in the hole w/ a steel shim gasket and 84cc heads should net you approx 10:1
Coming soon!!!!
Re: 10.5 to 1 pistons [Re: rss] #705077
05/22/10 09:37 PM
05/22/10 09:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That's why the piston manufacturers publish piston compression height. This way you can do the calculations yourself: block deck height - (piston compression height + rod length + (stroke/2)) will give you how far in the hole your pistons are. However you are still making assumptions about machining variances in the rods/crank/pistons as well as you are assuming to KNOW what your block deck height is. Can't accurately just take the factory published # because the factory blocks do vary in deck height.
383man [Re: DaytonaTurbo] #705078
05/22/10 11:57 PM
05/22/10 11:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Piston manufactors give advertised comp ratio on the assumption of all stock specs. And of course on the BB Mopar the year and head will need to be known. I always figure I will have to do final machine work to get the comp I want with any piston. I always like to cc my heads and know my deck height before I get pistons but no matter how you figure it you always have to assemble the pistons in the shortblock and take final measurements to get the exact comp you are after. Ron
Re: 383man [Re: 383man] #705079
05/23/10 01:32 AM
05/23/10 01:32 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Not necessarily true. For example,
For KB, advertised compression ratios are based on 0.030 overbore and combined deck height/gasket thickness of 0.040".
http://www.kb-silvolite.com/article.php?action=read&A_id=15
For Diamond flat tops for a 440 piston, they use 0.012" deck height and 0.040" gasket thickness (9.9 CCs).
http://www.mopartsracing.com/parts/diamond.html
0.012" difference would result in about 0.2 compression points difference.
383man [Re: rss] #705080
05/23/10 02:42 AM
05/23/10 02:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I see what you mean. I guess I was thinking more on the line of stock replacement type pistons and not so much of race or higher comp pistons. You know when you would see a Speed Pro piston for a 68 to 71 340 with 10.5 comp I would say they are talking stock pistons for stock specs. Or Speed Pro 11.0 pistons for a 68 to 70 440 hp. My assumption would be they are based on a 906 head stock spec 440 eng.
But you are correct for most hi performance pistons of today are based on comp hieght specs and so on. And the more I think about it most pistons really cant be sold with an eng comp ratio listing because they dont know what heads are going to be used so unless they are a stock replacement piston I guess they have to go on comp height ? Ron
Re: 10.5 to 1 pistons [Re: DAMOPARS] #705081
05/23/10 08:16 AM
05/23/10 08:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'll ask the STUPID question ... WHAT ENGINE are you talking about ?
There are a lot of ASSumptions in this thread without knowing the engine size.
Re: 10.5 to 1 pistons [Re: JohnRR] #705082
05/23/10 04:25 PM
05/23/10 04:25 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Why does it matter what engine it is?
10.5 pistons are sold for SB and BB right?
If you want to go with mine it is a 400 - 440 crank
4.375 bore .035 over 3.750 stroke 6.768 rods 1.320 CH -6cc pistons 80 cc heads
I was just curious
Re: 10.5 to 1 pistons [Re: DAMOPARS] #705083
05/23/10 07:11 PM
05/23/10 07:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Actually, NO, 10.5 pistons aren't sold for every engine and there are many factors involed to come up with a compression ratio.
As far as Chrysler engines go the factroy OVERRATED the compression of many engines and the replacement pistons available don't match , except for a very few, what the factory installed.
Re: 10.5 to 1 pistons [Re: JohnRR] #705084
05/23/10 09:47 PM
05/23/10 09:47 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i think the factory rating was for NHRA blueprint specs.
a '69 340 would be 10.5 if built to the legal NHRA specs which allowed 63 cc heads etc.
a stock head is 70 -72 cc and will probably yield about 9.0 : 1 or so.
...but you really have to do the math.
Re: 10.5 to 1 pistons [Re: can.al] #705085
05/23/10 10:02 PM
05/23/10 10:02 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
69 340 nhra specs...allows 63.3 head cc ...piston is .045 above deck...head gasket is .035
I bet the compression is higher then 10.5 to 1...
Tony
