1973 dodge dart fenders fit a 1972 dart?? #704712
05/22/10 08:36 AM
05/22/10 08:36 AM
Lower West Michigan
mopardave66 Offline OP
Lower West Michigan
will a 1973 dart front fender fit a 1972 dodge dart?the 1973 donor car is a 4 door does that matter?
Re: 1973 dodge dart fenders fit a 1972 dart?? [Re: mopardave66] #704713
05/22/10 09:03 AM
05/22/10 09:03 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
If your asking if a 72 and 73 Dart fender are the same, the answer is no. If you wanted to use a 73 fender on a 72 the entire 73 ft cap would need to be used. If a 73 ft cap is used the only things that may not bolt directly up are the hood latch support, and I don't know about the bumber brackets matching the 72 holes on the frame rail.
