Re: Electrical Headache
[Re: flatiron]
#704368
05/21/10 03:12 PM
05/21/10 03:12 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Battery up front or in the back?
What is the base ignition timing at?
What is the voltage at the battery when cranking?
With the key off what happens when you jump the starter relay?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: flatiron]
#704370
05/21/10 05:19 PM
05/21/10 05:19 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Make sure you have a good ground from the battery to the block and all the connections are good.
Take a metal pipe from above and rap the starter a couple times don't let it touch the wires.
Try jumping the relay again.
If it turns the brushes are worn out on the starter and either it needs to be rebuilt or replaced.
If that don't work have the battery load tested.
Allen
[Re: terzmo]
#704377
05/22/10 07:21 PM
05/22/10 07:21 PM
Posts: 7,506 Az
Crizila
Az
Don't forget the neutral safety switch on the trans. Make sure the 3 prong plug is not loose.
Fastest 300
[Re: flatiron]
#704379
05/23/10 12:24 PM
05/23/10 12:24 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Since you have not tested the battery what happens when you swap it with a know good one or just jump it with another? When jumping the battery use the block for ground.
Amperage is what turns a starter and not much is needed to keep the head lights brite a sub par battery will power headlight and yet will not turn a motor over. Again check all connections starter too.
Allen
