Re: TIRE SIZE FOR CUDA?? [Re: SIXPAK440] #704086
09/01/11 06:11 PM
09/01/11 06:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Follow Health services instructions and you will be able to see fine. Caps are yelling.
Re: TIRE SIZE FOR CUDA?? [Re: stumpy] #704087
09/01/11 06:42 PM
09/01/11 06:42 PM
Nebraska
Dodge-N-Shelby Offline
Nebraska
I run 275/60/15 BFGs on the back of our 73 Barracuda. They are mounted on factory 15x8 Ramcharger steelies with dog dish caps. They are a little tall for my taste but fit very well with no rubbing anywhere. Front has 235/60/15 on stock 15x7 steelies.
Re: TIRE SIZE FOR CUDA?? [Re: Dodge-N-Shelby] #704088
09/01/11 07:49 PM
09/01/11 07:49 PM
North Dakota
Azzkikrcuda Online content
Azzkikrcuda  Online Content
North Dakota
15x8 with 4.5 inch backspacing and 295-50-15's rear and 15x7 with 245-60-15 front.
Re: TIRE SIZE FOR CUDA?? [Re: Azzkikrcuda] #704089
09/01/11 10:52 PM
09/01/11 10:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IMO on a 7" rim a 255 60 15s on the rear and 235 60 15s on the front.. then I would buy a much better tire...
I am truckless..
Re: TIRE SIZE FOR CUDA?? [Re: 340SHORTY] #704090
09/01/11 11:34 PM
09/01/11 11:34 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
MT street drag radial 295/55 on 8" weld draglite and skinnies on the front. cuda
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704091
09/02/11 02:02 AM
09/02/11 02:02 AM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I like P215/65R15 on 15X7s. They look like P235/60R15 but are a little taller tire. P275/60R15 on 15X8s with 4.5 inch backspacing on the rear.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: TIRE SIZE FOR CUDA?? [Re: Azzkikrcuda] #704092
09/02/11 03:46 PM
09/02/11 03:46 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The backspacing for an 8" rim at 4.5 is the secret to make it fit properly, essentially keeping the factory centerline...example: with the factory 7" rim, the backspacing is 4". Further, if someone wanted to run a 9" rim, the correct backspacing should become 5" to retain the factory centerline. I have 16x10" wide rims on my Challenger T/A which I use for E/SP SCCA Solo II atocross competition (running Hoosier A6 275x45x16 tires) and the rims (Centerline "X" series forged aluminum race rims) hace only a 5" backspace.. so, they do extend outwards toward the fenders 1/2" too much, but then I've flushed my fender lips and slightly pulled them out to still appear original (flairing is allowed with class rules, though I chose nothing too extreme)... and even with a super-stiff suspension, and lowered, the tires do not hit my fenders .. about 1/2" clearance overall. I believe the 70-74 Cudas have slightly less fender room as compared to the Challengers (in my opinion and have seen/compared).
Mopar Mitch
Re: TIRE SIZE FOR CUDA?? [Re: Mopar Mitch] #704093
09/02/11 07:37 PM
09/02/11 07:37 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If no one noticed, this is an old thread that got booted up when a new member decided to try and be funny.
Re: TIRE SIZE FOR CUDA?? [Re: B5 Bee] #704094
09/02/11 09:18 PM
09/02/11 09:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used a 68-70 B-body Dana , springs moved in 1" on each side.
rears - 15x8's with 4.25" backspacing and 295-50-15's
ft's are 15x7's with 235-60-15's
Torsion bars have been cranked down since this picture was taken
Re: TIRE SIZE FOR CUDA?? [Re: gtx6970] #704095
09/02/11 09:20 PM
09/02/11 09:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
rear shot
Re: TIRE SIZE FOR CUDA?? [Re: gtx6970] #704096
09/02/11 09:21 PM
09/02/11 09:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
spring clearences
Re: TIRE SIZE FOR CUDA?? [Re: gtx6970] #704097
09/02/11 09:22 PM
09/02/11 09:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
overall
Re: TIRE SIZE FOR CUDA?? [Re: Azzkikrcuda] #704098
09/02/11 09:34 PM
09/02/11 09:34 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
Not to hijack, but how do the rears fit? Any rubbing? Did you have to move the springs in or do any modifications to get them to fit?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
