Re: TIRE SIZE FOR CUDA??
[Re: kingkt]
#704067
05/21/10 10:21 AM
05/21/10 10:21 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Suggestion = Use the search function. This topic has been covered at length for years.
Comment = You are ultimately limited by the narrow rim size and backspacing you have.
Request = Take off the CAP LOCK!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: kingkt]
#704070
05/21/10 12:23 PM
05/21/10 12:23 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
PLEASE TURN OFF THE CAPSLOCK.
Please turn off the capslock.
Now which one do you think is easier to read?
275-60R-15 will usually fit on the rear with 8" wheels with 4.5" backspace. They will be close to the wheelwell lip if the car is low and might need a little cut and/or bend where they are close. If it is higher in the rear like with SS springs then no problem.
[Re: GomangoCuda]
#704071
05/21/10 12:24 PM
05/21/10 12:24 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
275 60 15 rear, 235 60 15 front BFG Radial TA. Personally, I wish the fronts were just a little taller.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: GomangoCuda]
#704076
05/21/10 03:19 PM
05/21/10 03:19 PM
Posts: 2,826 NY usa
540challenger
NY usa
you young guys might be able to see the smaller letter better. but us old farts see the larger letters better. anyways thank you for the info.i appreciate it to all.
Please define "young guys" and "Old Farts". What hair I have left is white and I have grandkids in college. Am I an old fart?
Being an old fart is not defined by the color of your hair but rather how many places on your body it is now growing.
[Re: Azzkikrcuda]
#704089
09/01/11 10:52 PM
09/01/11 10:52 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IMO on a 7" rim a 255 60 15s on the rear and 235 60 15s on the front.. then I would buy a much better tire...
I am truckless..
[Re: kingkt]
#704091
09/02/11 02:02 AM
09/02/11 02:02 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
I like P215/65R15 on 15X7s. They look like P235/60R15 but are a little taller tire. P275/60R15 on 15X8s with 4.5 inch backspacing on the rear.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: Azzkikrcuda]
#704092
09/02/11 03:46 PM
09/02/11 03:46 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The backspacing for an 8" rim at 4.5 is the secret to make it fit properly, essentially keeping the factory centerline...example: with the factory 7" rim, the backspacing is 4". Further, if someone wanted to run a 9" rim, the correct backspacing should become 5" to retain the factory centerline. I have 16x10" wide rims on my Challenger T/A which I use for E/SP SCCA Solo II atocross competition (running Hoosier A6 275x45x16 tires) and the rims (Centerline "X" series forged aluminum race rims) hace only a 5" backspace.. so, they do extend outwards toward the fenders 1/2" too much, but then I've flushed my fender lips and slightly pulled them out to still appear original (flairing is allowed with class rules, though I chose nothing too extreme)... and even with a super-stiff suspension, and lowered, the tires do not hit my fenders .. about 1/2" clearance overall. I believe the 70-74 Cudas have slightly less fender room as compared to the Challengers (in my opinion and have seen/compared).
Mopar Mitch
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
