Hi,
Has anyone used the new direct connection valve covers on a big block yet?
The reason I'm asking is because the size of the openings in the valve covers. All the openings look to be about the size of a PCV grommet. That means that one valve cover will have an opening for a PCV and the other cover will have a hole too small for a regular oil cap (at least that's how I see it). Maybe there's a special sized oil cap that should be used with these covers?
