Non computer controlled overdrive transmission #703938
05/21/10 12:15 AM
05/21/10 12:15 AM
Charleston, SC
safaritow Offline OP
Charleston, SC
Did mopar make a overdrive Automatic transmission that would work in an old truck with a small block?
Re: Non computer controlled overdrive transmission [Re: safaritow] #703939
05/21/10 12:16 AM
05/21/10 12:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
94 & earlier 518 with or with out lock-up convertor...
Re: Non computer controlled overdrive transmission [Re: 1_WILD_RT] #703940
05/21/10 12:18 AM
05/21/10 12:18 AM
Charleston, SC
Charleston, SC
Is the lock up converter manual?
Re: Non computer controlled overdrive transmission [Re: safaritow] #703941
05/21/10 01:01 AM
05/21/10 01:01 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
46RH is what you are looking for which is based on the 727
42RH is also available which is based on the 904
Tony
70 AARCuda Vitamin C
Re: Non computer controlled overdrive transmission [Re: safaritow] #703942
05/21/10 01:35 AM
05/21/10 01:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On the overdrive transmissions the lockup is electric.
Re: Non computer controlled overdrive transmission [Re: safaritow] #703943
05/21/10 01:47 AM
05/21/10 01:47 AM
hooziewhatsit Offline
Manual in the sense that you can add some switches to make it shift automatically. The RE version required a computer to shift it.
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
