Cylinders Scuffed Vertically #703850
05/20/10 10:02 PM
05/20/10 10:02 PM
NJ
440challenger Offline OP
NJ
Pulled my 446" out of my challenger to take a peak inside and change the oil pan.
I pulled the pan and was looking at the cylidners and theres a good amount of scuffing on the cylinder walls right where the skirt is lonnger on the piston. This is a .030 440 with ross 82008's. What causes this/ is it normal?
Re: Cylinders Scuffed Vertically [Re: 440challenger] #703851
05/20/10 10:19 PM
05/20/10 10:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dirt,,,if you have a pile of miles on it...yes it is
Re: Cylinders Scuffed Vertically [Re: MR_P_BODY] #703852
05/20/10 10:29 PM
05/20/10 10:29 PM
NJ
NJ
hmm dirt ? the motor has been together for 6 years. i got some hard time on her
Re: Cylinders Scuffed Vertically [Re: 440challenger] #703853
05/20/10 10:31 PM
05/20/10 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... dirt... could have even been in there when
you did the engine
Re: Cylinders Scuffed Vertically [Re: 440challenger] #703854
05/20/10 10:31 PM
05/20/10 10:31 PM
UK
602heavy Offline
602heavy  Offline
UK
Will also depend on piston to wall clearance , short stroker pistons are prone to this (rock).
Re: Cylinders Scuffed Vertically [Re: 440challenger] #703855
05/20/10 10:35 PM
05/20/10 10:35 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Racing an engine that has not been properly warmed up can cause scuffing as well
Re: Cylinders Scuffed Vertically [Re: Dunnuck Racing] #703856
05/20/10 10:56 PM
05/20/10 10:56 PM
Hemiroid Offline
Hemiroid  Offline
I've noticed that Ross skirts always seem scuffed no matter what the use. Not sure why, just been my experience.
Re: Cylinders Scuffed Vertically [Re: MR_P_BODY] #703857
05/21/10 08:56 AM
05/21/10 08:56 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
you did the engine
Dirt for sure...
Re: Cylinders Scuffed Vertically [Re: Hemiroid] #703858
05/21/10 10:27 AM
05/21/10 10:27 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've noticed that Ross skirts always seem scuffed no matter what the use...
I believe someone else on here made a similar comment recently. They certainly do seem to have some thin skirts compared to other aftermarket pistons I've seen.
Re: Cylinders Scuffed Vertically [Re: BradH] #703859
05/21/10 07:37 PM
05/21/10 07:37 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my CP's did the same thing to my 360 block.
Re: Cylinders Scuffed Vertically [Re: BradH] #703860
05/21/10 07:50 PM
05/21/10 07:50 PM
(I have made those comments before) I have built and dynoed tested a lot of motors with Ross pistons, it seems to me that they have delicate skirts, mark up very quickly and do mark the cylinder walls up some in the break in process also I'm now using Diamond brand pistons for those reasons
Re: Cylinders Scuffed Vertically [Re: Cab_Burge] #703861
05/22/10 07:38 PM
05/22/10 07:38 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
chamfering the bottoms of the bores with a grinder to take off the sharpness helps to prevent piston scuffing.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Cylinders Scuffed Vertically [Re: 68 HEMI GTS] #703862
05/22/10 11:31 PM
05/22/10 11:31 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
15 runs with Ross pistons & i had very noticable scratch marks. the sharp edge of the bottom of the bore was scouring my pistons draging crap up for the piston to scratch on it's way down on a compression stroke. chamfered the lower boere lip & my KB pistons look great & so does my bore.
Re: Cylinders Scuffed Vertically [Re: Dunnuck Racing] #703863
05/23/10 06:47 AM
05/23/10 06:47 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
