Re: what would you do? wiring question
[Re: mike69rr]
#703569
05/20/10 07:37 PM
05/20/10 07:37 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Plug it in as is, except bypass the ammeter with either a shunt or just put both wires on one post.
If everything works, do the bulkhead mod if you still want to.
Mark the wire on the bulkhead for easier id if you wish to do it later on.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: ahy]
#703573
05/21/10 12:50 AM
05/21/10 12:50 AM
Posts: 10,219 Someplace you aren't
SomeCarGuy
I have ran the YO harness with electronic ign and late model VR on several cars. I bypass the amp meter and run a shunt.
No problems.
If you want to do the bulkhead job, run it first like was said to make sure it works OK. The YO harnesses are nice pieces.
I want my fair share
